Tekno RC EB48 Thread >
Like Tree2Likes
Old 05-23-2014 | 07:19 PM
  #12496
FastPete's Avatar
Originally Posted by rvinvents
my sct410 turns like a dream i can turn inside anyone and put it wherever i want on the track, where as with the eb48 i feel like im just hanging on for the ride most of the time, the buggy should out turn and out handle the sct410 right?
IMO absolutely! And it was great indoors hard packed clay. I know it sounds opposite but a friend of mine said he went 10K F and it was dialed!
FastPete is offline
Old 05-23-2014 | 08:41 PM
  #12497
rvinvents's Avatar
im at 7/10/5 and it seems like my front is diffing out, front wheels looking like pizza cutters at times
rvinvents is offline
Old 05-24-2014 | 01:25 AM
  #12498
im at 7/10/5 and it seem like my front is diffing out, front wheels looking like pizza cutters at times
Is it a slick track or a high bite track?
Checked the diff fluids lately to make sure the cases are full?
Are you WOT a lot causing it to diff out?
If all that is good try turning your "punch" down on your esc or your current limiter depending on what brand esc you run. The tuning features found nowadays in most common escs can really help you dial a car in at times.
MattP is offline
Old 05-24-2014 | 03:10 AM
  #12499
Mizchief's Avatar
Some ballooning is normal, but if too excessive you can try taking out some front droop, stand up rear shocks more, or a stiffer rear spring, then would try anti-squat last.
Mizchief is offline
Old 05-24-2014 | 03:27 AM
  #12500
Slotmachine's Avatar
that is good to know, it seems the buggy really likes the stiffer springs in the rear, i was thinking the spring was causing the slight bucking in the rear, but i can see how the purple would help turning, are you running on clay or outdoors? your droop is way different than mine im at 104 front 119 rear maybe im not getting the weight transfer to the front also?
I run hard packed outdoor good traction.
I have the same issue, I run 553, pink front, purple rear. 104,122 Outside hard packed and clean. Its great everywhere but 180 turns just don't want to turn unless you slow WAY down. Was thinking about trying the lower inner hole on the tower for camber link, im one up from the bottom now. Rear end seems really locked in nice, im sure adding to the steering issue.
Maybe try the forward hole on the ackerman for tight 180's.
Slotmachine is offline
Old 05-24-2014 | 08:33 AM
  #12501
rvinvents's Avatar
indoor med-high bite
just rebuilt them all and filled them to the top of the gears
yes it is happening when i am WOT when it breaks loose so im not too worried about it, and thats what i run in my sct410 and its perfect, should a buggy be different?
Im at 25% current limiter rx8 gen2 and tekin 1900 16t pinion
the spread between the f/r springs is so huge compared to sct i run greens f&r but you buggy guys are using pink/red why is that? lol i guess im a buggy now trying to learn to tune, it's a bit different than my truck.
more or less anti squat?
ok, does the bump steer mod (flipping the balls) help on indoor med-high bite
Old 05-25-2014 | 10:46 AM
  #12502
RokleM is offline
Old 05-26-2014 | 12:01 AM
  #12503
Mizchief's Avatar
For those of you running lt. blue front and orange rears, what pistons and oil you using?
My car is just about perfect now, but i need just a touch more on power coming out of the corner. I would be willing to give up some turn in as I have some to spare, but otherwise don't want to change up how it's handling in other areas.
Mizchief is offline
Old 05-26-2014 | 06:50 AM
  #12504
8ight-e's Avatar
775, good throttle control
My buggy is hooked, pretty normal to throw the fastest laps of the day w/ this setup.
8ight-e is offline
Old 05-26-2014 | 10:24 AM
  #12505
rvinvents's Avatar
since i got my buggy second hand, i am not sure which hubs are on it, can somebody post the width of the stock hubs so i can verify if i have them vs +1 or +2
Old 05-27-2014 | 08:16 AM
  #12506
justpoet's Avatar
Not at my car right now, but stock has no milling and is your usual hex. If it looks like a hex, rather than a star, they're normal. From memory the pin is centered in the edge of the hex on stock width, vs being closer to the inside of the car on the + width hexes.
justpoet is offline
Old 05-27-2014 | 08:43 AM
  #12507
jhautz's Avatar
You should be able to tell by looking at them.
Standard hex:
Plus 1mm Hex:
Plus 2mm hex:
jhautz is offline
Old 05-27-2014 | 10:36 AM
  #12508
Cain's Avatar
hmm, nice post. I must have a +1 or +2 on mine then. Will measure and find out for sure.
Cain is offline
Old 05-27-2014 | 04:06 PM
  #12509
Genebaby's Avatar
I attended my first big race meet where the cars were scrutineered. I was told that my car was the widest and the lightest EP car.
It "just" made it through on width and I have the standard hubs.
Genebaby is offline
Old 05-27-2014 | 07:41 PM
  #12510
Got 3 practice sessions on our new buggy on a very dusty track, car looks terrible, besides washing it what would normal maintenance be, any body oil or grease outdrives or pivot balls,etc, how long should bearings hold up on the EB in dirty conditions thanks
Nurcdad is offline
