Tekno RC EB48 Thread >
Like Tree2Likes
Old 05-29-2014 | 12:27 AM
  #12526
LAZNICK RC's Avatar
Hi guys
Does anyone know where to buy shock tower bra protectors for the tekno carbon fibre towers front and rear!!
Ones that fit !!
LAZNICK RC is offline
Old 05-29-2014 | 06:07 AM
  #12527
Sent protc3 a pm about purchasing his inserts. Is that the correct way to go about it? Also, I'm wondering if these inserts have been tested in the ET48?
Highspeedsentry is offline
Old 05-29-2014 | 06:52 AM
  #12528
8ight-e's Avatar
Originally Posted by goldy
Are you using std or +1.5 brace on your set up?
+1.5 is STD on the 48.2; but yes, it is the +1.5 stock part.
8ight-e is offline
Old 05-29-2014 | 07:05 AM
  #12529
Cain's Avatar
Tech Legend
for your setup with the 1.2 x 8 hole piston in the rear, would you recommend this for conditions that are very very rutted or would say the 1.3 x 8 hole setup be better on the rear?
and if so, any suggestions on what spring and oil weight combo to use?
Cain is offline
Old 05-29-2014 | 07:52 AM
  #12530
Nick@Jet's Avatar
Yes that is the correct way, he is VERY helpful. Give him some time as he is a business owner and most likely fairly busy
Nick@Jet is offline
Old 05-29-2014 | 04:20 PM
  #12531
So if you are using the centre dot pill the total toe will be 4 degrees.
goldy is offline
Old 05-29-2014 | 05:33 PM
  #12532
Slotmachine's Avatar
Originally Posted by LAZNICK RC
Hi guys
Ones that fit !!
You can use the sct 410 body mounts and just trim them down a bit........
Slotmachine is offline
Old 05-29-2014 | 07:49 PM
  #12533
I ordered 2 sets last week he said it was his last ones so may take a while before he makes some more
Nurcdad is offline
Old 05-29-2014 | 09:24 PM
  #12534
8ight-e's Avatar
This is the best setup I've found for any outdoor condition... I've hit several tracks different days different moistures blown out not blown out... it's just dialed. I swap tires per conditions but setup has yet to be tweaked again. Tq and 2nd tonight; threw the fastest lap and top 5 fastest laps of any vehicle including nitro buggies with a pile of outstanding drivers (the next fastest was my et48 that took the win). I had a couple tangle ups that just cost me too much time early in the race to catch back up.. got it close though I guess the one good thing, I lost to another tekno :P
Yup, mind you LRC pills in the rear and lowest setting the rear front pills.
Not sure if I noted this on the setup sheet... no center brace and rear brace is in place, but not screwed into the rear diff case up top.
I run the same LRC setup in my truggy and everyone is amazed by how well it handles.. so yes and yes they work well. Same setup lowest position on the front rear pills and the lrc rear pills.
8ight-e is offline
Old 05-29-2014 | 11:09 PM
  #12535
rvinvents's Avatar
this came up a few pages back, so I contacted TEKNO direct and was told by thomas that the pics in the first page and the eb48 manual are incorrect, with the 1.5 hanger I was told to refer to the NB48 manual it is correct and the eb48 manual and set up sheets will be corrected in future printings, here is a snap shot of it. and it shows the center dot being 3.5 deg.
rvinvents is offline
Old 05-30-2014 | 04:09 AM
  #12536
So this picture shows the toe in with the 1.5 rear block fitted, correct? Just looked at the first page of the sct, and they don't add up right either! This needs sorting.
goldy is offline
Old 05-30-2014 | 09:38 AM
  #12537
rvinvents's Avatar
yes as quoted to me by tekno, the nb48 set up sheets reflect the newer 1.5 rear hanger and the degrees shown are correct.
Old 05-30-2014 | 10:02 AM
  #12538
rvinvents's Avatar
A while back I mentioned I was going to try the durango 18T aluminum pinion and a few of you wanted me to post results, I found it to be super smooth and quiet, and the weight savings are very noticeable on acceleration and braking (actually had to turn the brakes down on sct), I ran it for 3 nights in my sct 410 and my eb48 on high bite clay with some hard on throttle landings, and it shows no signs of wear, I wish they made it in a 17t though as 18t is a little too tall for my sct, see the weight savings as compared to my 17t pinion, below
Old 05-30-2014 | 02:29 PM
  #12539
Hello!! Have I a couple of questions, which pine kernel recommend me for a motor " Mamba moster " 2200kv?? It is a technical circuit and without big straight lines, finally. That contribute the manguetas optional 15 degrees TKR5042B ?? thank you very much, regards!!! Sorry for me inglis .
vixarraku is offline
Old 05-30-2014 | 05:09 PM
  #12540
1900kv is all you need 2200 is to much.
slimgravy is offline
