Tekin Pro 4 HD Factory Thread >
Like Tree1Likes
Old 04-27-2014, 11:34 AM
  #616
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
Thanks,gonna put another motor in 1st!
OfnaJoe is offline
Old 04-27-2014, 11:36 AM
  #617
fq06's Avatar
Trader Rating: 12 (100%+)
That too, just gotta start eliminating things till you find the culprit
fq06 is offline
Old 04-27-2014, 11:45 AM
  #618
Trader Rating: 358 (100%+)
Originally Posted by OfnaJoe
Our 1st outside race of the year was today and I put my new Pro4 4300 HD in and it was ballistic for the 1st pack and I parked it until the race started and on the 2nd lap it shut off like it hit the LVC. I got it back to the pits and was messing with it and Tekin RX8 Gen2 was doing right, all the leds was working but the motor wouldn't go. I spun the pinion and it took off. If it comes to a stop it wont start again but if you keep it running it works fine. Any ideals what to look for?
I just put my Sct410 together with R10 pro and Orion 550 motor. Was doing the exact samething. Thru Rx8 in with same motor. No issues, thinking it was the ESC.
jmoneym is offline
Old 04-27-2014, 11:59 AM
  #619
OfnaJoe's Avatar
Just put my Tekin Pro4 4000 back in and it ran perfect. Changed and put the Pro4 HD back in and same thing but I did notice that if the shaft stopped with the flat part for the pinion screw facing me it had to be "kicked started" if it stopped facing away from me it would start back on its own. Could it be a bad sensor ? Are this motors warranted over 5 mins? Always had great luck with Tekin till this.
OfnaJoe is offline
Old 04-27-2014, 12:29 PM
  #620
fq06's Avatar
You can turn the ESC and radio on and slowly turn the wheels to check the sensors. There will be 3 lights on the ESC that will cycle, only 2 a sensors not picking up. They are extremely dim, do it in a place without a lot of light.
fq06 is offline
Old 04-27-2014, 01:38 PM
  #621
OfnaJoe's Avatar
Only see 2 LEDs , looks like 1 on each side and the one in the middle don't come on.
OfnaJoe is offline
Old 04-27-2014, 02:51 PM
  #622
fq06's Avatar
That's on the other motor? Or the HD?
If its on the other motor it may be the sensor wire. Even if its on the HD it may still be the sensor wire.
fq06 is offline
Old 04-27-2014, 03:22 PM
  #623
Team Tekin
Randy_Pike's Avatar
IT can be the sensor board, yes. If you're using a Tekin esc you have an onboard sensor tester! Make sure to use it!
Randy_Pike is offline
Old 04-27-2014, 03:23 PM
  #624
Team Tekin
Randy_Pike's Avatar
Watch this video..it's tough to see the 1st sensor at times due to the neutral led being on...there's a trick:
Click HERE
Old 04-27-2014, 03:26 PM
  #625
Team Tekin
Randy_Pike's Avatar
Make sure you're using 250 software: www.teamtekin.com/hotwire.html
Next use the sensor checker feature to verify the sensors are read by the esc.
Also, verify the A B C wiring by removing the senor harness entirely, and attempting to power the motor. It should cog a bit but should drive the motor without issue. Does it?
Old 04-27-2014, 04:57 PM
  #626
Getting ready to buy a SCT410, will be installing a RX8 Gen2 with a Pro4HD 4300. There are 2 small-medium outdoor tracks in my area. I live in South Texas and the ambient temperature is hot which is why I decided on a 550 can to help keep temperatures down. What pinions should I buy?
RoyOne is offline
Old 04-27-2014, 05:06 PM
  #627
OfnaJoe's Avatar
3 good LEDs on the other motor, only 2 on the HD
OfnaJoe is offline
Old 04-27-2014, 05:26 PM
  #628
OfnaJoe's Avatar
OK, Just put a brand new sensor wire on it and still don't work. If you spin the shaft to get it going I think it is 3 lights on, if you don't spin the shaft I know it's only 2 lights on. I guess it only fires 2 poles at the same time. With the other Pro4 not HD it works fine and with a RevTech it works fine, What could it be other than a bad sensor on the motor?
OfnaJoe is offline
Old 04-27-2014, 06:30 PM
  #629
Hoese37's Avatar
You need a new sensor board in the motor.
Hoese37 is offline
Old 04-28-2014, 02:30 AM
  #630
OfnaJoe's Avatar
That's what I'm thinking too. Now to find one!
OfnaJoe is offline
