Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 04-15-2014 | 12:40 PM
  #2566
Ya I went ahead and ordered it a few minutes ago what pinion are you running with it?
turtletrax is offline
Old 04-15-2014 | 12:45 PM
  #2567
What exactly are the white pistons in the bags with the bladders?
Old 04-15-2014 | 01:05 PM
  #2568
The white ones are 8x1.3 pistons.
mr240 is offline
Old 04-15-2014 | 01:11 PM
  #2569
T. Herwig's Avatar
I like 17 tooth with that motor personally.
T. Herwig is offline
Old 04-15-2014 | 01:42 PM
  #2570
Building my new kit....whats the best way to install the balls in the rod ends that go on the turnbuckles w/o damaging any parts?
nitro0619 is offline
Old 04-15-2014 | 01:47 PM
  #2571
Mizchief's Avatar
I usually stick in one end then squeeze them in with a pare of channel locks.
Mizchief is offline
Old 04-15-2014 | 02:15 PM
  #2572
sramos's Avatar
Use the protek shock tool. It has a rod end specific tool in between the handles
sramos is offline
Old 04-15-2014 | 02:33 PM
  #2573
These shocks are so easy to build and get to match. I LOVE that they have the aluminum parts and not the plastic like my sct 410.
^ I usually just push on my rubber pit mat but the ends I just did on mine I used washers on a screw and tightened nut down to pop em on real quick. Same goes for shock shafts. If you use nut on top of shaft(without piston) you can use nutdriver to put your shock ends on without ever risking marking up the shock shaft by grabbing it with pliers
Old 04-15-2014 | 02:35 PM
  #2574
FastPete's Avatar
I use the smooth part of needle nose, wiggle the rod end pops right on.
FastPete is offline
Old 04-15-2014 | 02:36 PM
  #2575
Awesome that's what I was hoping. And thanks Tyler I'll try 17
Old 04-15-2014 | 04:21 PM
  #2576
jmcelroy42's Avatar
I just received my kit from tower hobbies, should my kit have the correct diff shims? I thought the correct ones were darker, the ones in the kit are silver and I can't seem to find the posts about it.
jmcelroy42 is offline
Old 04-15-2014 | 04:27 PM
  #2577
The new shims are silver.
munrath is offline
Old 04-15-2014 | 04:28 PM
  #2578
jmcelroy42's Avatar
Great, thanks!
Old 04-15-2014 | 05:20 PM
  #2579
Anyone had any trouble with diff housings breaking?? I was a little over zealous with my throttle control and wheelied out of a corner right before a jump.. the front end shot straight down off the jump face and went straght into the face of the landing... it was a direct hit to the top of the front shock tower.. It ripped the bottom screws out that connect the shock tower to the diff housing... it was a pretty vicious hit for any vehicle to take?? Just wondering if anyone else has had this happen to them?
sour powered 05 is offline
Old 04-16-2014 | 01:35 AM
  #2580
Originally Posted by kawi650
No problems, all reasonable questions.
Thank you Sir!!
mamdot91 is offline
