Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 04-07-2014 | 06:42 PM
  #21136
tc5 man's Avatar
Tech Prophet
Originally Posted by Graham11
My Evo body is awesome. No parachute at all.
However, I am having problems with my rear breaking loose under power coming out of turns, any recommendations to fix?
Try removing the center and rear chassis brace off . Or just the outside upper hole on the rear arms . Do add some lead weights like 2 1/4 oz ones on the rear end.
Reduce the dual rate to 92% on your radio i think thats what makes the rear end swing around on exit turns with to much dual rate.
tc5 man is offline
Old 04-07-2014 | 06:46 PM
  #21137
Going to try some low profile lock nuts and cutting all the excess axle that shows. Maybe that will prevent anymore broken axles...
iTz Nicholas72 is offline
Old 04-07-2014 | 07:18 PM
  #21138
tc5 man's Avatar
Tech Prophet
Originally Posted by fq06
When I was running the stock chassis I cut a new slot at the front of the pack and pulled it up at the very back of the tray... no slot needed at the back.
You can always go back to forward lipo position if you want, just route the strap back through the forward slots.
Im going to try the very back slot on the battery tray . That could benefit me since i race on mostly dry lower traction outdoor tracks especially during the summer. Might jump a little better also.
tc5 man is offline
Old 04-07-2014 | 07:21 PM
  #21139
rvinvents's Avatar
I tried that, I did 1 out of 4 to see what would happen, it was the only one I broke LOL, I think the problem lies with the borrego wheels for me, the next set i will try something different, too bad I really like them.
rvinvents is offline
Old 04-07-2014 | 07:32 PM
  #21140
JRapid's Avatar
Originally Posted by feelgood
Just raced my SCT410 for the first time Saturday, love the truck but even with the lowest body mount settings the body sits very high, especially up front. Is this due to the body I'm running (JC high flow Titan) or are most of you moding the mounts somehow?
Thanks!
No mine's the same way with my Hi-flo. I really wish I could lower it just a little bit more. Unless you make wider mounts, the massive shocks/tower will always be in the way to lower them.
JRapid is offline
Old 04-07-2014 | 07:36 PM
  #21141
skengines's Avatar
What springs are most of you running for an outdoor track? I currently have yellow/green.
skengines is offline
Old 04-07-2014 | 07:38 PM
  #21142
I currently have a cracked rear angled diff case. I'll order another. Sounds like some of you have had success in boiling them? I guess I'll give it a shot when I get the new one. I haven't had it in there very long. While I do preform some pretty good crashes, the stock one never broke on me.
honda95freek is offline
Old 04-07-2014 | 08:03 PM
  #21143
tc5 man's Avatar
Tech Prophet
That will depend on what kind of dirt surface you race on. How you want the truck to handle etc.
Im going to try the Green springs all around on the outdoor tracks .
tc5 man is offline
Old 04-07-2014 | 08:09 PM
  #21144
Brandonmorris44's Avatar
I run grey hb springs front and rear on loose sandy low bite tracks and have success
Brandonmorris44 is offline
Old 04-07-2014 | 08:10 PM
  #21145
T. Herwig's Avatar
The yellow rears have been my favorite. I've messed with other combos, but always fall back to these.
T. Herwig is offline
Old 04-07-2014 | 08:14 PM
  #21146
Green front
Orange rear
Need to order a pink front and yellow rear to try
Old 04-07-2014 | 08:17 PM
  #21147
ChuckTee's Avatar
Originally Posted by Mizchief
Did you do all the cutouts on the EVO? I did all of them and I could barley tell i had a body on it in air.
I did afterwords on the reccomendation of a buddy that runs it, Everywhere else it was fine except for that one jump where its almost a free fall before you hit the straight. So between cutting out all the holes and putting the air dams on it solved the problem and now I like it and aint pissed thinking that I wasted time and money....Thank God. I need options with bodies and now I have some.
ChuckTee is offline
Old 04-07-2014 | 08:31 PM
  #21148
tc5 man's Avatar
Tech Prophet
Well my used FTW body is trashed now after racing yesterday the body holes are ripped and cause the body post with the body clip go under. In the 2nd main race the body shifted and i ended up running with no body lol.
I ordered a high flow JC body.
tc5 man is offline
Old 04-07-2014 | 09:15 PM
  #21149
If you like your rb6 like I do, try the kyosho orange front / yellow rears! They work very well on the SouCA tracks.
Kuya_Kimo is offline
Old 04-07-2014 | 09:54 PM
  #21150
Hoese37's Avatar
Anyone know if the black composite spur is any quieter than stocker?
It's the same as the white gear. Put the black orings in the drive shift cups. That will really quiet the driveline down.
Hoese37 is offline
