The AE FActory Team B44.2 Thread >
Old 03-19-2014 | 03:02 PM
  #7366
fq06's Avatar
Thanx for the info WC
Originally Posted by robbie_gtc
I searched and found a few mentions of it on here. But none about the length of screws used. There are 2 different sizes on the front tower and iirc. 3 in the rear. Was curious if someone had done it already amd knew the max length's etc.
I have cracked a couple towers front and rear. They are strong but we have a large triple with a wall on one side and posts on other. Get it wrong and its easy to smack one of those and crack a tower. Sealed the cracks with some c.a and glued them together. Would like to see how strong they can be and how long they last.
I'm not at home so I can't out my hands on a manual but you can download the 44.2 manual and get the screw sizes. I think the tower is 3mm so add that amount to the screw size in the manual. I will measure when I get home but almost positive they are 3mm.
fq06 is offline
Old 03-19-2014 | 04:20 PM
  #7367
Jmuck69's Avatar
Originally Posted by Waflet
Hideeho
I won't guess at a time frame, other than before 2015 1/10 worlds , but I expect a new AE 4wd is coming. My guesses as to what will be different:
AL chassis, maybe offered in 2 lengths
beefed up arms (2 cars crashing out of worlds with broken arms )
new motor mount (only because the current one sucks so bad )
gear difs with ball difs as an option
metal ring & pinion gears on the difs
maybe using a shorty pack (see the new schelle racing chassis or the team c tm4 or the hpi d418)
the geometry will probably remain the same, but the way everything goes together will be tweaked to make it simpler & easier to work on (ball studs for the camber links in particular as well as to make it easier to get to the difs)
metric hardware (assuming it is a new platform not a .3)
The big question is going to be what they call it, assuming it is a new platform. b45? b54? b55?
I see something closer to the current Yokomo BMAX 4 as a possibility.
Jmuck69 is offline
Old 03-19-2014 | 06:30 PM
  #7368
Waflet's Avatar
Hideeho
I went & looked up the bmax4 III. As it turns out, other than using a shorty, I described the Yokomo to a "T".
Waflet is offline
Old 03-19-2014 | 07:47 PM
  #7369
anyword on a new AE 4wd?
xTotalghost is offline
Old 03-19-2014 | 09:24 PM
  #7370
fq06's Avatar
Tower is 4mm thick... actually like 3.8 but call it 4mm.
Just add that length to the screw lengths in the manual and your good.
Sounds like that goal post triple is a money maker for the track
fq06 is offline
Old 03-20-2014 | 06:29 AM
  #7371
hyperfuxx's Avatar
Will the 44.1 battery tray fit in the 44.2 chassis?
hyperfuxx is offline
Old 03-20-2014 | 07:31 AM
  #7372
No I tried
Old 03-20-2014 | 08:06 PM
  #7373
Thanks! The 2WD'S roll it. But all the 4wd's jump it so gotta keep up.
And they definitely sell a good 3-4 towers every club night
robbie_gtc is offline
Old 03-20-2014 | 09:12 PM
  #7374
Lol i cracked mine and just put some CA on it and pressed it down with the plyers and ima run it for now lol
Old 03-20-2014 | 10:22 PM
  #7375
ok guys im having some problems with my .2
im running
Front 35, 1.6, blues 21mm
rear 30, 1.7,greens 20mm
2mm rear arm mod
barcodes clay coumpound F/R red aka inserts
7.5 lrp flowworks team
60%epa
avid chassis
rear ballast avid steel weight plus 42grams
everything else box stock
indoor track medium to low grip clay wet to dusty
cant get the rear to settle down there is no confidence
what changes could i do to get more confidence inspiring traction
especially on throttle
also if possible could you explain why those changes will give me traction so
i can understand
you know the saying
instead of just giving me a fish
please show me how
thx farmer
BakoFARMER is offline
Old 03-21-2014 | 05:25 AM
  #7376
hlpressley's Avatar
Anyone have any spring, oil, and piston recommendations for small bore shocks with BB springs? Running on a small/medium outdoor track with no large jumps. Any help or starting points would be appreciated. Thanks in advance.
hlpressley is offline
Old 03-21-2014 | 06:05 AM
  #7377
fq06's Avatar
im running
2mm rear arm mod
60%epa
avid chassis
i can understand
you know the saying
please show me how
thx farmer
Best thing to do is try things one at a time, if it doesn't help, change it back to how you had it and go to the next change.
Run you slipper looser, less initial power delivery spike, like traction control. Set it to just have enough power to get you over the biggest jump.
Try the black rear sway bar instead of silver, allows the chassis to roll more.
Try the ackerman hole in the front of the link, calms down steering at the expense of less aggressive steering in slow tight turns. Check your toe out and endpoints after changing.
Less front toe out, less entrance steering, more exit steering.
You can change the roll center with camber links but for now try those and if that doesn't get it report back.
The arm mod shortens the wheel base to try to get to 44.1 length? Go back to 44.2 length, that should calm down the chassis and it also affects the angle of the rear driveshaft and if its pushing the tires into the ground or pulling them up from it.
You have unintended consequences when you go that much further forward than AE intended the arm and axle angle to be. Angle the axle too far forward and it wants to lift the chassis like adding more anti squat.
Maybe others have suggestions past that.
fq06 is offline
Old 03-21-2014 | 07:12 AM
  #7378
im running
2mm rear arm mod
60%epa
avid chassis
i can understand
you know the saying
please show me how
thx farmer
Farmer it's not just you buddy. The track is just not very forgiving with all the fast 180* turns in it. Last Friday I went to f 32.5 blues 1.7 and rear 27.5 green 1.7 with the rear hubs all the way forward. Car was better but still not the way I wanted it. I went out last night and the car seemed worse, I moved the hubs all the way back and not any better (or worse). I think I'm gonna try loosening the front diff and moving the rear camber links out one hole. It sucks cuz my 2wd buggy is really good right now and my 4wd just went to shit. Try moving that rear camber link out 1 hole tho. I did that on my 2wd and it was a great move
skoalisbad4me is offline
Old 03-21-2014 | 07:22 AM
  #7379
fq06's Avatar
Loosening the front diff may make it worse. Front should be 1/16 out from tight and rear should be 1/8 out from tight. A tighter front than rear will make the front pull it out of a turn, more understeer than oversteer.
A shorter rear link should give you more steering and a little more straight line traction.
Longer link decreases the camber gain and makes it less responsive and slower camber change through the arms travel.
Razathorn... RC direction correct?
With that said, its real easy to make these changes at the track. Try it and see, if its worse, put it back and try something else
fq06 is offline
Old 03-21-2014 | 07:40 AM
  #7380
Potoczak's Avatar
+1 any idea when we might see a new version with gear diffs and metric hardware???
Potoczak is offline
