Argus USA Engines Thread
#1396
I am not a big fan of Os plugs but they will work fine, just dont overtighten them. The P3 is too hot and can mask a improperly tuned engine.
I have ran the 0801 pipe on many engines and it works well on anything. I have not ran the Tb-1 but it is a great pipe for the price. I am pretty sure Argus would not be selling it if it didnt work well with there engines.
Rex
Rex
What plug would you recomend running in the Argus motors and also what fuel would you also recomend I have been running Powermaster last year and a Morgan brand of fuel for the few years before that and I am looking at changing fuels and will be sending you a copy of resume as well as I already know a couple of the guys that have signed on and we will be running together this year. I have been running the Alpha motors for the last 4 or so years so already know what to expect.
#1397
Rex,
Run a fuel that has some castor or add castor to it. I have used a morgan fuel the last couple years and liked it. Byrons is always good.
Rex
#1399
The 2014 Argus team is building up nicely, thanks for all that sent resume's. I still have a few more spots open, send the resume's to [email protected]
Rex
I have had a few ask about the cranks, you could say they are factory modified, they come like this stock.
Rex
#1401
Finished breaking in the R8 on the bench with quart of 25% Powermaster containing an ounce of caster. Gonna drop in the truggy this weekend and was wondering which pipe would work the best 0801, 2071, 053, 086, 2013.
#1402
Rex
#1404
as far as i know, for alpha, 0801 for best runtime and power throughout the revrange. 2081 for most bottom end and next best runtime, cant remember top end pipes, i use the 2081 with alpha A852 for lots of bottom end. the 2107 alpha lutz pipe has changable stingers for adjustable power band
#1405
did you try any of the other pipes yet. Im gonna try out the tb-1. Gonna see how it pulls a .23 in a truggy around. New year new pipe new engine. I already know the 0801 pipe works great for the alpha models. so since i have the werks and 0801 pipe i guess i can try all 3 of them out and see what really works. the best for runtime and power.
#1406
hello,
i just replaced my A5 piston/sleeve and i can't get it started like first i got it, can anyone help with:
1. idle gap:_____
2. LSN:_____
3. HSN: ______
what i get from page 50 is:
1. LSN: 1/2 turn in from flush
2. HSN: 1/2 turn out from flush-but it will die when i remove the igniter. thanks in advance
1. idle gap:_____
2. LSN:_____
3. HSN: ______
#1407
hello,
1. idle gap:_____
2. LSN:_____
3. HSN: ______
1. idle gap:_____
2. LSN:_____
3. HSN: ______
#1408
hello,
1. idle gap:_____
2. LSN:_____
3. HSN: ______
1. idle gap:_____
2. LSN:_____
3. HSN: ______
Idle gap .7 but wider would not hurt for break in
lsn I would start 1/2 turn in from flush.
Hsn 1/2 turn in from flush sounds good.
If it does not seem to suck fuel take the carb apart and clean it. I have seen old fuel gum up after sitting. While it is apart put some fine 600 grit sandpaper on a smooth surface and sand both side of the banjo fitting in the hsn assy.
Rex
#1409
Thanks guys, it was a success.
Actually how many litre to fully break in this engine, my old 1 break in for 15tanks.
I'm asking for recommendations since the pinch is crazy after 12 tank with heat cycling method
#1410
you will most likely have mechanical pinch up to about a gallon and a half or two. then it will drop it nuts and when that happens you will know cause you will have to re-tune it a little. but you do not have to be easy on it. i normally i put a small race tune on mine right after break is done. but leave it rich just a little. after i get a couple of track races on it i think i go to a fall balls out race tune around the gallon mark. this is the same gallon i use for break in just so you know. i also think i play it a little safer then some might. some people are full race tune right after break in. but i play it safe cause the track will give it true testing in a race.
1Likes
