The AE FActory Team B44.2 Thread >
Old 03-10-2014 | 07:58 PM
  #7291
Thank you thank you thank you!!! You guys are awesome
brandon1116 is offline
Old 03-10-2014 | 08:11 PM
  #7292
Thank you guys!! I got it!!! You guys are awesome
Old 03-10-2014 | 08:23 PM
  #7293
UN4RACING's Avatar
This thread is one of the best I have ever seen for support. Sort of a one stop support shop...
UN4RACING is offline
Old 03-10-2014 | 08:32 PM
  #7294
Wildcat1971's Avatar
Tech Prophet
I am wanting to minimize chassis slap and allow more roll in the corners. I race on an outdoor bumpy track. I was thinking about tying 1.3x4 pistons in the rear. My understanding is more small holes = more pack, but also more low speed roll.
Here is my track.
https://www.youtube.com/watch?v=5qyG...JV_i33VjYn47zw
Wildcat1971 is offline
Old 03-10-2014 | 08:49 PM
  #7295
Oh great get one problem solved now my servo is acting all crazy!! After I'm done steering it freaks out and starts going back and forth real fast
Old 03-10-2014 | 08:59 PM
  #7296
silveraider14's Avatar
Here is my track.
I just started running those this past weekend.
22wt oil in the rear.
1.5 flat pistions with 27.5 weight oil in the front.
still needs some tuning but it doesn't slap as hard like the 1.7s did
silveraider14 is offline
Old 03-10-2014 | 09:06 PM
  #7297
mschumi101's Avatar
Is this a new servo and radio system? Have you used the same combo in the past on this car or another? Some servos require glitch busters in the receiver to work properly, such as savox servos with low powered spektrum receivers.
mschumi101 is offline
Old 03-10-2014 | 09:18 PM
  #7298
UN4RACING's Avatar
Just run it till it quits and buy a new one. Mine does it to. I cant remember what its called but its trying to find center. If you touch it it will quit.
Old 03-10-2014 | 09:32 PM
  #7299
Yeah but sometimes it won't stop!!! I gotta keep turning it for a little bit to make it stop!! I went cheap I have the orange receiver and a turnigy trakstar ts-920 would a glitch buster work or should I just order a new servo because sending it back probably wont be worth it
Old 03-10-2014 | 09:43 PM
  #7300
UN4RACING's Avatar
I don't know of that servo. But I would just run it unless its causing the kit to track bad. I have been running mine like that all season. I do have a back up on hand though.
Old 03-11-2014 | 06:39 AM
  #7301
Wild Cherry's Avatar
Default basic RC 101 class
Bigger holes or more holes in the piston makes for less pack...
Smaller holes or fewer makes more pack..
Enjoy......
Wild Cherry is offline
Old 03-11-2014 | 08:02 AM
  #7302
Dustin's Avatar
Anyone have gear diff conversion input shafts they want to part with? Or who do I get ahold of to get some made?
Dustin is offline
Old 03-11-2014 | 06:39 PM
  #7303
Mxer59's Avatar
How well does the 44.2 hold up? Jw everyone one at my track is xray or Rango as of recently and looking into a 4x4 buggy
Mxer59 is offline
Old 03-12-2014 | 01:26 AM
  #7304
Amordus's Avatar
Hi Guys,
I have a original B44 that i have updated with all the parts to bring it to a B44.1 except for the chassis its still the original one with the holes for the old 6c battery's.
I want to update it to a B44.2.
Has anyone installed the Avid Aluminum Chassis upgrade for b44.2 to an original b44 and if so have there been any problems with fit out?
Thanks in advance !!!
Amordus is offline
Old 03-12-2014 | 05:03 AM
  #7305
jimmeh's Avatar
Thanks to people like you! I watched all your videos before I built my 44.2 then had them for reference whilst building!
A few posts back someone was talking about setting the slipper. I have always set the baseline for the slipper on the track with allen key in the slipper hole, the rear wheels in the air, pushing the fronts till they skidded. From there, maybe a quarter or half turn back or forward as grip changes. I find this to be the most consistent for the track and most logical way of setting it.
Shimming the diff's till they are just right takes feel and logical thought. Using your method of building diffs have never lost a diff gear in the past 6 months of racing (6.5turn)!
I cannot speak more highly of the information in your vids and highly recommend them to the newbies!! Hint: they're on the first post!
jimmeh is offline
