Team Associated TC6 Thread >
Like Tree20Likes
Old 02-17-2014 | 12:49 PM
  #9976
rc car guy's Avatar
If you have built the car correctly then your rh should be able to be adjust easily on my 6.1 I put my atock springs on had to.turn them down 1/3 the way in the rear and about 1/8 the way in the front
rc car guy is offline
Old 02-17-2014 | 01:00 PM
  #9977
Originally Posted by billdelong
how about posting a pic, should be easier for folks to see what you're doing with the setup.
Are you going pro-squat instead of anti-squat on the rear?
I just have the stock kit from Team Associates, which, I believe, does not include either pro or anti.
I will try to post a pic, but the last time I did I was unsuccessful because I didn't have the minimum required posts.
Thanks for you continued help.
JB
boylrmakr is offline
Old 02-17-2014 | 01:23 PM
  #9978
Can someone tell me what offset wheels are used with a 190mm body and what is used if I want to run a 200mm body?
bigbeej is offline
Old 02-17-2014 | 01:46 PM
  #9979
JB
Check out this build thread here:
http://www.petitrc.com/reglages/asso...yPhalen_Build/
Take note on step 49... there are different arm mounts with different dot height markers... this will allow you to adjust pro/anti-squat... if you're using dots that bump up the height of the rear arms too high, this might effect your ability to control your ride height possibly, perhaps you can swap out the arm mounts?
Any chance you happened to swap the front rear shock towers by mistake?
billdelong is offline
Old 02-17-2014 | 01:52 PM
  #9980
I've always had the best luck with 0mm offset for 190mm bodies
Most prefer 3mm offsets with 200mm bodies, but I kinda like the look with 6mm offset wheels to better fill in the space... it's a matter of preference and how much traction you're willing to give up with a wider track width, of course not all 200mm bodies are the same either... I'm currently running a 200mm body with 0mm offsets and it doesn't look too bad
Old 02-17-2014 | 02:00 PM
  #9981
JB
bring that thing to the community center on sat we will get it figured out. wait, your in the seattle area right? i thought you said you were.
dragonracing is offline
Old 02-17-2014 | 02:52 PM
  #9982
I've used the recommended "0 dot" arm mounts for this and the build is correct for the rear arms. According to the chart, this "recommended" "0 dot" setup equates to a flat standard roll center. Yes and good question regarding the front and rear shock towers. I checked and double-checked that they are installed in their correct locations.
If I disconnect the shocks, then the wheels can travel downward far enough to give the 5mm ride height and more. I've checked the shock builds and your recommended 62mm length, so they must be correct. I'm perplexed.
Any other suggestions. I've put 2 pics in my album, but I don't know if you can view them or not.
Thanks,
JB
Old 02-17-2014 | 02:58 PM
  #9983
Yes, I'm in the Seattle area and I plan to be at the CC Saturday. I'll bring it along for you guys to check out.
Thx,
JB
Old 02-17-2014 | 03:16 PM
  #9984
try backing out the threaded ball ends on the shocks a few turns, it's possible that they may be over tightened?
Or any chance that the wrong ball ends may be installed in the shocks?
Old 02-17-2014 | 04:05 PM
  #9985
That will work, but I'd have to back them out about 1/8" which is about 1/2 of the threads on the shock shaft. That seems like it will weaken the support on the shocks.
There is only 1 type of ball end in the kit, so I don't think they are the wrong ones.
Thanks,
JB
Old 02-17-2014 | 06:11 PM
  #9986
ok, please add a pic of your gauge and where your measuring from. it appears that you might be trying to measure with a droop gauge. show me your gauge please. just add a pic in your gallery.
Old 02-17-2014 | 06:36 PM
  #9987
Ok it's in there. It's the Integy combo RH/Droop guage. I'm using the steps on the right. Can only get 2mm height with shocks fully extended. The front RH adjusts just fine.
Thx
JB
Old 02-17-2014 | 06:45 PM
  #9988
thats the droop gauge portion of the gauge. you want to use the steps to the left. lay the gauge down and use the thin steps for ride height. to use the droop gauge the side of the ride height portion goes against the bottom of the chassis and measuered at the bottom of the hing pins. so in the pic knock that thing over and use it that way. ok good? understand?
Old 02-17-2014 | 06:50 PM
  #9989
when you come to the CC hit me up and ill show you how to use it. just look for the red ferraris. F1 and my GT car are ferraris.
Old 02-17-2014 | 07:20 PM
  #9990
Thanks for the insight (feeling pretty lame) Now I have another problem with the height being too high and I have the shocks fully backed off, so any more advice is welcome.
I'll certainly drop by and look at your rigs.
Thanks again,
JB
