Mugen MBX6
Im in the same boat as you hobdog with my mbx6 constantly looking for more steering. The track I normally run at is a small, tight, indoor track. 90% of my friends run a 8ight at the track, the 8ight is a great car, turns great and is very nimble in the tight sections where I get left at, lol. I am the kind of person that likes to be different though and tries different cars. The only car I have ran at this track that is as nimble and turns as great or better than the losi is an Agama. I liked that car alot but had to get rid of it for a few reasons. The Agama kind of spoiled me when trying all the other cars because now I know how good one of these cars can turn. My current car is a teckno converted MBX6 and i have tried almost everything to get this thing to turn how I would like it to. So far from a basic setup I have changed rear toe to 2.5, tried different caster settings but settled back to stock center because I am looking for more off and on power steering. Completely removed the front sway bar, and moved rear outer hub hinge pin location to lower hole, tried various ackerman settings (returning to stock because that is just a compromise as well). Also ran SS double dees in the front and soft impacts in the rear. That made it steer well but isn't the answer. Diffs are currently 7/7/3 seems to be the best compromise. Next thing I am going to try is moving my camber link locations and rear lower roll center setings around. The car is close to where I want it now and I think moving those will make it about right.
Got myself a nice used 6. Yeah the OG. Will start testing after undoing the mess I did with a pin and two shafts, seems they don't go one from another in one pass, and shatter...and a hammer is not enough...and now I have a mbx5r shaft and a mbx6 shaft connected by one pin.
Dude buy yourself a proper Pin Press/chain breaker. They can be had for 30-40$ on ebay.
I'm liking this car so far,wow much quality.
I'm going tomorrow to some bike/motorcycle shop see if they have something like this.
THis is exactly what your looking for. Not your link
http://www.ebay.com/itm/ATV-Bike-Mot...0af544&vxp=mtr
Ive heard Many of pins breaking on some of the Name brand Tools, Ill stick to what's worked for 100's of pins over the years.
And I DO NOT suggest the HUDY, If you think replacing pins with a Hammer is the way to do it, well your sadly mistaken. Hardened pins Can and will shatter if your not careful as you have found out.
3Likes
