The AE FActory Team B44.2 Thread >
Old 02-03-2014 | 01:19 PM
  #7036
Wildcat1971's Avatar
Tech Prophet
he is looking to run 13.5 4wd at the cactus classic. So I am fairly certain his plan is not to go slow. It is also a non boosted class. So he will need to run 13.5 with motor timing only. Gino. I would start where I said, then adjust for temps. I am sure you have all of the pinions and spurs to try stuff out. 13.5 4wd is just not super popular. But i plan to run 13.5 in my wheeler this weekend and I plan to start where I told you.
Wildcat1971 is offline
Old 02-03-2014 | 01:28 PM
  #7037
Svendc's Avatar
24 or 23 pinion on 81 spur
Yes that's much better, ratio. 30 75, run that on 17.5 blinky. But 8.5 mod motor with that ratio aauws, motor will Come very Hot
Svendc is offline
Old 02-03-2014 | 01:35 PM
  #7038
Svendc's Avatar
Originally Posted by turbo2cam
sounds about right to me. That's what I would gear a 2wd buggy for 13.5, and the b44.x uses same rear tire and same internal FDR as B4.x, so you should/would gear this using the same pinion/spurs.
You can't compare a 2wd ratio with a 4wd ratio, 4WD has much more resistance
Svendc is offline
Old 02-04-2014 | 11:06 AM
  #7039
greenruby79's Avatar
Default Avid Slipper..
Hello guys, just got the Avid Triad Slipper kit and going to install them on my car. Also got the Avid spacer for the kit. Question, where do i place the Avid spacer on the Triad kit? Do you guys have pics on where do i place them? Thanks in advance. Cheers...
greenruby79 is offline
Old 02-04-2014 | 01:58 PM
  #7040
turbo2cam's Avatar
oh you most definitely can compare the two! The math used to figure out either car's FDR is the same...neither the 2wd or 4wd FDR uses resistance as a consideration...so yes you can compare the two. There are sooooo many variables for "resistance" how can you even begin to quantify such an animal??
As far as pinions...a 23/24 with 75 spur will be VERY slow with a 13.5. That's what I run on my 8.5 lolol. maybe with a TON of boost a 24/75 combo might work...but for sure not in blinky.
This is what AE recomends for the B4.2 (gearing will be VERY close for the b44, even with "resistance" taken into account, tire size is same, spur is same, pinion is same, diff's are same, etc.)
17.5 blinky = 32/75
17.5 w/boost = 23/78
13.5 blinky = 30/75
13.5 w/boost = 22/81
8.5 = 22/81
So yea.....
turbo2cam is offline
Old 02-04-2014 | 04:56 PM
  #7041
mschumi101's Avatar
17.5 blinky = 32/75
13.5 blinky = 30/75
8.5 = 22/81
So yea.....
Makes sense, I don't think resistance would play a large factor, but one thing to consider with the B44 versus the B4 is that very little air flow will reach the motor in the B44. So heat will become a factor. The B4 motor is exposed so it can cool much easier than under a closed body. So you may have to sacrifice a couple teeth to keep the temps down. That being said I've run a boosted 7.5 with a 22/75 in my B44 when it was cool outdoors. So it really depends on the situation. Racing indoor now I can't come anywhere close to that ratio, nor do I need to.
mschumi101 is offline
Old 02-04-2014 | 06:37 PM
  #7042
17.5 blinky = 32/75
13.5 blinky = 30/75
8.5 = 22/81
So yea.....
i run 21/81 on my 7.5
xTotalghost is offline
Old 02-04-2014 | 06:43 PM
  #7043
Tech Prophet
so I just put a 13.5 in my car. well, a 29/81 does not fit....so yeah....I need a smaller spur. but until I pick one up, I just boosted it up for now. so I am 81/25 boosted.
Old 02-04-2014 | 10:02 PM
  #7044
mschumi101's Avatar
Just FYI with a 75t spur, the minimum pinion is 22 teeth. But it looks like you'll be surpassing that. Haha
Old 02-05-2014 | 06:07 AM
  #7045
Svendc's Avatar
17.5 blinky = 32/75
13.5 blinky = 30/75
8.5 = 22/81
So yea.....
If you make the difference between boosted and blinky it's correct, but saying 8.5 30/75 (like in a post above) that's overkill.
7.5t, i run on indoorcircuits 20/81 with 10-20 degr turbo, no boost.
Svendc is offline
Old 02-05-2014 | 06:42 AM
  #7046
Tech Prophet
huh> we said 30/75 for "13.5", not 7.5. He is looking to run a wheeler in the 13.5 super stock class at the Cactus Classic. Its a real class, lol. He cant boost or use a lower turn motor.
Old 02-05-2014 | 07:06 AM
  #7047
turbo2cam's Avatar
I don't see anyone talking about using a 30/75 on an 8.5. We've been talking 13.5 blinky gearing for last couple pages. Then WC had to go and throw his usual BS into the mix and that's where the 8.5 gearing got brought up (because the ratio's he is recommending would be shit for a blinky 13.5, but normal for 8.5)
Super Stock 13.5 4wd Buggy is getting to be a normal class around here it seems (for indoor clay tracks) same with SS Truck and SS Short Course. I really like 13.5's I feel like those and 10.5's are the best all around motors.
Would be cool if there was more motor regulated classes IMO.
Stock = 17.5 blinky
Super Stock = 13.5 blinky
Mod = 10.5 blinky
Open/Pro = Anything
Old 02-05-2014 | 07:14 AM
  #7048
Tech Prophet
lol, way too many classes, lol. Anyway, I drive the motor I can handle. On my currently layout, I am not liking the 8.5. I can only use the speed on the straight. And the jumps are close together and a wheeler with a 8.5 is just harder for me to get right. We also have a tabletop jump with a crap ton of lift and it is way to easy to over power the jump and land in the fluff. Add to that my tires are getting destroyed. Tires are only lasting me 1-2 race days. And the guy that won the wheeler class last weekend ran a 13.5 boosted in a xxx-4 chassis. So its not like an 8.5 is a huge advantage.
Old 02-05-2014 | 07:22 AM
  #7049
MiCk B's Avatar
Hi,
Have a read of this post:
http://www.rctech.net/forum/11740921-post2656.html
Image:
MiCk B. :-)
MiCk B is offline
Old 02-05-2014 | 07:25 AM
  #7050
MikeXray's Avatar
Ok folks , this weekend I rand A big race, 5 qualis and 4 heats. Test the Rpm arms and the 2mm shorter rear arm mod. Man the car felt good. Fast, stabel and on low speed loose anough in the rear, to turn very Quick. Run on medium grip Astro, wooden jumps and Stones Run 3 days without one little problem. Run one of my best races ever so for. My mate is A-main driver and swaped last heat his xb4 with my b44.2 and afther one round to test he go as Fast with my b44.2 as his best. Finished 3e in that round with his best time of the Day. Hé comes of the rosarium, and says, man I never drive A car so easy and good like You're b44.2.
I love my b44.2, I'm proud of him. It was a hell of a test.
Gtz
What rear arms are 2mm shorter?
MikeXray is offline
