Official Tekin RX8 GEN2 ESC Thread
#1666
http://www.teamtekin.com/hotwire/ESC...pbell_v238.pdf
#1667
#1668
I think I got a DOA Gen 2 RX8. After wiring everything up and going through all the programming etc. I get the the flashing trouble code that indicates "Incorrect motor type selected" I double checked the setting in Howire and it is set correctly. I wired up another T8 thinking maybe the motor was bad, but I still have the same issue.
#1669
I think I got a DOA Gen 2 RX8. After wiring everything up and going through all the programming etc. I get the the flashing trouble code that indicates "Incorrect motor type selected" I double checked the setting in Howire and it is set correctly. I wired up another RX8 thinking maybe the motor was bad, but I still have the same issue.
#1672
#1673
#1674
I did that. Twice actually. When I have it plugged in via the Hotwire the motor selection is correct. I also tried changing the firmware version to see if that made any difference. I just hooked my Gen 1 RX 8 up to the same motor and receiver and it works fine.
#1675
Please contact [email protected] The guys will take care of you.
#1676
Ok, that narrows it down right there. If the Gen1 works and the Gen2 doens't and you're sure the settings are right, it's bad.
#1677
I just installed RX8 Gen 2 brand new yesterday - (changing from Gen 1). INstalled - radio calibrated, tried to connect via APP for the first time and no go, but truck would run fine so I ran the practice night thinking it was issue with my phone. When I tried the APP - my Galaxy note 2 wouldn't connect. So today hooked up my laptop for regular Hotwire and also cannot connect.
APP - Galaxy NOte 2 Android version 4.1.2
Regular HOTWIRE:
Green light flashing on HOTWIRE
Red on "DB" on the RX8
Laptop - i hve always connected this laptop so no issues there
PS: I don't know what version of Tekin software in RX8 G2 since i cannot connect. I just purchased this off Horizon so I believe it is recent
1. Can you shed some light on this, really excited to use the data logging and App
2. Is there a link to the datalogging manual - cannot find on Tekin website
thanks
Regular HOTWIRE:
thanks
#1678
Did you download the latest firmware to your laptop? You should.
Sometimes my notebook will not connect and I have to shut down hotwire and open it back up. Then it connects.
Make sure you hold the inc button to clear the data that came in the ESC so you can record your own data.
For the app, try using it with the lipo powering the ESC and the ESC switch on.
#1679
Hey guys,
I have just got my MP9e build by my brother Nasser & my mate Abdullal Alfalah.
46 spur & pinion 15, Tekin RX8 Gen 2 & Tekin 1900kv motor
Please help me by giving me a good set up for
The ECS.
Thanks,
Mohammad
The ECS.
Thanks,
Mohammad
#1680
App - still no go, tried uninstalling app and reinstalling and still the same
1. Will start in Demo mode
2. When I connect it says "Connecting to Speed Control", in the upper left corner it changes from DEMO to V246, then "Connection to.." box goes away, but I cannot see any data.
3. Tried with battery connected and switch on and it will only start in DEMO
4. HW box still flashing green and RX8 G2 RED light on at DB position.
see pics
20Likes
