Like Tree5Likes
SC10 4x4 Thread
Old 12-18-2013 | 08:09 AM
  #35716
Cain's Avatar
nice find!
Cain is offline
Old 12-19-2013 | 05:41 PM
  #35717
benbishop98's Avatar
tomorrow will be my first attempt at a real race. i haven't had my sc10 4x4 for long but what i have done so far is diffs (front 20,000/ rear 5,000), chassis brace, front and rear sway bars, jconcept subculture tires and that's about it. then again if you can't keep it right side up and on the track all the hop ups in the world won't help you win. the track is clay and pretty slick. any suggestions on a good set up for a beginner?
benbishop98 is offline
Old 12-19-2013 | 06:51 PM
  #35718
Don't be afraid to set your endpoints "low". There's tons of steering in the car, once i dialed mine back the steering was nice, smooth and a lot more controllable
lee111m is offline
Old 12-19-2013 | 10:11 PM
  #35719
rcuser67898578 is offline
Old 12-20-2013 | 07:25 AM
  #35720
Cain's Avatar
what conditions are you running on?
I am assuming you won't have tons of time to change a bunch of stuff around, and its probably a good idea first to start with what you got unless your setup is really off.
what I can recommend is:
- Grab some setups off of AEs site that appear to match your conditions
- When you have issues, compare to those setups to get any idea of what could be useful to change
- Download and take with the Xray Hudy Offroad setup guide as well as the Mark Pavadis guide. These can be had for free.
Cain is offline
Old 12-28-2013 | 10:38 AM
  #35721
Shark413's Avatar
Wow this thread has been kind of quiet lately. Well here is something I have been working on. I have been running my X-Factory SCX SC truck and Durango DEX210 buggy in mid motor configuration and both use a 4 gear tranny. The advantage of a 4 vs 3 gear tranny is the motor rotation is in the same direction as the wheels. This should enhance traction on power and allow better altitude control. One of the big problems I have with my SC10 4x4 is I am not happy with the altitude control. It is much better since I have added a cDiff but no where near my Tekno. So I started researching a 4 gear setup on an SC10 4x4. Well no one makes an aftermarket 4 gear tranny case, but Marcus (RCShox) did experiment with a modded SC10 4x4 4 gear setup and he gave me a place to start. I pretty much copied a lot of his ideas, but went with a steel idler instead of plastic for durability. I also went with a "C" support for the idler rather than a spindle for more support. There were a lot of things that need to be worked out, motor mounting (the top mount is where the idler now sits), finding a 32p idler gear, make the "C" support, etc. I was able to get a prototype built and bench tested it. I still have a couple of issues to work out and a lot of fine tuning. Then I need to see how it holds up under full power. Here are some pictures.
Modded motor mount uses an extended slot and two screws on the bottom to hold the motor.
"C" support to hold the idler gear to the motor plate. Idler is a 32p pinion drilled out to accept two 5x10mm bearings.
"C" support bolted to the motor plate.
Front view, showing belt clearance.
Bench testing at 1/2 throttle.
Shark413 is offline
Old 12-28-2013 | 11:25 AM
  #35722
MarqueeRc's Avatar
Sweet!
Love the ingenuity!
MarqueeRc is offline
Old 12-29-2013 | 08:54 AM
  #35723
I will pay whatever you want to charge plus an arm and a leg, but really only a leg. I need two arms too drive like a pro. I could stand on one leg with no problem.
coconut is offline
Old 12-29-2013 | 03:42 PM
  #35724
Shark413's Avatar
After testing my first attempt at a 4 gear modded tranny I decided to make a few improvements and also try another design I considered. I originally went with the "C" support for the idler because it is stronger. I also considered a spindle to hold the idler, which would be easier to make and be more compact.
To help me line things up and locate where new holes need to go I decided to make a clear copy of the motor plate. I clamped the stock motor plate to a piece of lexan.
Used a thin sharpie to trace the holes.
Shark413 is offline
Old 12-29-2013 | 03:43 PM
  #35725
Shark413's Avatar
Dup
Shark413 is offline
Old 12-29-2013 | 03:47 PM
  #35726
Shark413's Avatar
For the idler I used a 32P pinion that I bored out to accept a 5x10 bearing. Using the clear motor plate I found that an 18T idler was best, it allowed clearance for the belt and allowed me to use a 14-16T pinion on the motor.
Modding the pinion to fit a 5x10 bearing.
Shark413 is offline
Old 12-29-2013 | 03:51 PM
  #35727
Shark413's Avatar
For the spindle I decided to use some 3/8" 6061 aluminum rod I had. I turned down one side to fit the 5x10 bearing, drilled and tapped both ends.
Starting on the spindle.
Finished spindle and idler gear.
Shark413 is offline
Old 12-29-2013 | 03:57 PM
  #35728
Shark413's Avatar
The clear motor plate allowed me to check alignment of everything. Once everything looks good, I will use the clear plate as a template to transfer the mods to the aluminum plate.
lining up the idler gear and spindle. I found a 18T idler allowed me to use the upper motor mount hole for mounting.
Spindle allows plenty of room for the belt.
Everything installed, once I verify the alignment I will use the clear plate to transfer mods to the actual aluminum motor plate. I need to add another slot for the 2nd motor screw.
Shark413 is offline
Old 12-29-2013 | 03:58 PM
  #35729
Shark413's Avatar
Originally Posted by MarqueeRc
Sweet!
Love the ingenuity!
Thanks, but I stole the idea from Marcus.
Shark413 is offline
Old 12-29-2013 | 04:00 PM
  #35730
Shark413's Avatar
I wouldn't want that on my conscience, but let me do some actual track testing to see how it holds up and performs before you start cutting anything, lol.
Shark413 is offline
