Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 12-20-2013 | 11:31 PM
  #856
Originally Posted by metoo
Still haven't ordered the truggy, but I got a slew of tires and wheels and an ESC (VTX8), now I just need to decide which motor between 1900-2100kv and if it should buy a short or long can motor. Our track is not very big. It's clay and gets dry an dusty quickly in the Summer. It holds moisture ok late Fall thru early spring.
Buggy 2050 ...youll still make 10min at bigger tracks
rkhess is offline
Old 12-21-2013 | 04:35 PM
  #857
JeremyMcG's Avatar
Rx8 Gen2 combo ordered! 289 from tower!
JeremyMcG is offline
Old 12-23-2013 | 08:00 AM
  #858
Cain's Avatar
Thats kind of what i am thinking or Vipers new 2100Kv motor. The 2050 always had a bit more snot to it than the 1900 which could make it more of a bear in buggy. Maybe this would be perfect in truggy if doing the buggy motor thing.
Looks like a good amount of interest in truggy for the track i'll be attending.
Cain is offline
Old 12-23-2013 | 08:06 AM
  #859
skengines's Avatar
So instead of a truggy motor, you will be opting for a buggy motor instead?
skengines is offline
Old 12-23-2013 | 08:45 AM
  #860
2050 buggy motor is what I will be using.
MX304 is offline
Old 12-23-2013 | 09:27 AM
  #861
Cain's Avatar
yeah, that is what I am thinking based on what I saw the last time I did E Truggy.
Cain is offline
Old 12-23-2013 | 12:18 PM
  #862
boudin4evr's Avatar
what is weight difference between buggy 1900 and truggy 2000
boudin4evr is offline
Old 12-23-2013 | 12:24 PM
  #863
I believe its like 50-60 grams between the Tekin buggy and truggy motors.
kawi650 is offline
Old 12-23-2013 | 01:12 PM
  #864
boudin4evr's Avatar
so in my terms that is only around 1.8 ounces
that shouldnt make a difference! My rc8tce was a pig and had a Tekin2000 on 4s
and was a beast!
  #865
boudin4evr's Avatar
double post!
Old 12-23-2013 | 01:13 PM
  #866
I`ll be running Tekin Gen 2 1700 on 5s , ( allready have the combo ) will be putting in my order for the ET 48 at the middle January if finances work out .
mavdriver is offline
Old 12-23-2013 | 01:15 PM
  #867
Torian4000's Avatar
I'm going to start with a 2000kv Truggy motor on 4s. If I find it to be too much power I can always try a buggy motor. I'm not sure what pinions I should be using though?
Torian4000 is offline
Old 12-23-2013 | 01:44 PM
  #868
I would bet a 15 would be a good starting point depending on your track size of course
scorpion51503 is offline
Old 12-23-2013 | 02:34 PM
  #869
Cain's Avatar
if you get in touch with someone at the track to give you an idea of there gearing, use a speed calculator and back track that way to what speed you want to go with.
Or, gear for say 35mph to 40mph initially. That usually works to start.
Cain is offline
Old 12-23-2013 | 02:39 PM
  #870
Another reason I'm going with the buggy motor is that I ran one in my Associated truggy with good result, and I have a feeling the Tekno will be a lot lighter than that thing.
MX304 is offline
