Tekno ET48 Thread
#2358
Thanks, guys! I took the truggy out to the track last night and Damn, it's fast, jumps well, stays planted. I am impressed with the stock setup. Back end was occasionally sliding out -- a little tweaking to do. That's half the fun, right?
Metoo -- Your build thread was very helpful to me. You want to add the RC8T Bulldog body and DE Mud Guards to your list?
#2359
10/10/5
Yellow springs F/R
Go up in shock oil F/R
Reduce the droop F/R
Try these in stages
Hope this helps,
Mark
#2360
Hello all,
I have tried to search this forum for a 6s set up and haven't had much luck without reading 150 pages of forum. I am not new to racing and upgrading from my tlr 2.0 to the Tekno Et48. I am sure I can figure it out but I wanted to see what everyone else suggests for a good starting point.
Here is what I am running:
Tekin T8 1350
Hobbywing 160 amp xerun esc
6s battery
CSI v port blue pistons
Koyosho springs
Here is what I would like to know:
What diff oils for 6s?
What springs f/r ( koyosho is prefers) if no koyosho then please provide spring rates.
Shock oils with csi blues in mind?
Sway bars?
Any other useful info as far as bump steer, rear toe, etc.....
Please PM me so I receive it and can ask questions privately
Thanks,
Robert
Tekin T8 1350
6s battery
Koyosho springs
Sway bars?
Thanks,
Robert
#2361
Hello all,
Tekin T8 1350
6s battery
Koyosho springs
Sway bars?
Thanks,
Robert
Tekin T8 1350
6s battery
Koyosho springs
Sway bars?
Thanks,
Robert
As far as the Kyosho springs and CSI pistons, we're not too familiar with all of those options so we can't offer any good advice on those.
Start with the kit settings for the rest and go from there
#2362
Rear Tower - up and out
Rear Hub - 2nd from outside
Front Tower - middle and out
Front Spindle Carrier - outside
After I made these changes I could not break the rear end loose unless I was full turn and full break. I was searching for steering and the truck was pushing. Super easy to drive, but I had to set up for the corners. Still, I liked it and now I can make other changes to get more steering (remove steering stops, lower front ride height, raise rear ride height, etc.)
#2363
I raced in low bite track conditions last weekend and thought I could use some more overall traction. I changed link positions as follows:
I will try all these changes one at a time while at track practice and see what suits my conditions.
Txs again !!
#2364
Would it be possible for you to post the rest of your setup? Sounds like this would be an awesome starting point. And I agree--it's "generally" easier to dial in more steering than to calm down the rear end--I find this to be the case with virtually all vehicles.
#2365
+1
#2366
Hello all,
Tekin T8 1350
6s battery
Koyosho springs
Sway bars?
Thanks,
Robert
Tekin T8 1350
6s battery
Koyosho springs
Sway bars?
Thanks,
Robert
#2367
I have to tweak some more things before it's post-worthy.
#2369
Update on the Bulldog body: nice and durable, which I need
, but lets tons of dirt into the chassis! I am thinking about making some kind of shield to close the gaps around the sides.
#2370
I've got some new tires coming, so I want to test them before changing anything. Then I was thinking of going lighter on rear diff oil too. Thanks to Mark and Danny for the suggestions -- I will be trying some of those also. I already have some yellow rear springs which I am going to try out.
http://www.outerwearsracing.com/prod...sp?prod=202644
38Likes
