SR200WP w/transponder? >
Old 12-16-2013 | 04:38 AM
Default SR200WP w/transponder?
Can you use the bind port to power a transponder? It will be the only open port, or do I need to use an RX with an aux port? Thanks for any input for a newby.
Kris
Blackpearl#1 is offline
Old 12-16-2013 | 03:11 PM
racer1812's Avatar
Super Moderator
Yes, you can use the bind port.
racer1812 is offline
Old 12-16-2013 | 03:39 PM
JimmyG's Avatar
You cannot use the rc4 transponder in the bind port. The receiver goes into the rebind process. The rc4 is a 3 wire transponder which causes this. My futaba had this issue when I first got it.
JimmyG is offline
Old 12-16-2013 | 03:50 PM
Sorry I should have specified it is a two wire hybrid MYLAPS
Old 12-16-2013 | 04:05 PM
JimmyG's Avatar
Then everything should be fine.
JimmyG is offline
Old 12-16-2013 | 05:55 PM
Interesting. Have you by chance tried it with a Y servo harness on a throttle or steering channel? Just curious.
Dave H is offline
Old 12-17-2013 | 03:32 AM
Great idea. I would have never thought of that thank you very much and if I need to try it I will report back.
Kris
Old 12-17-2013 | 04:03 AM
Kris
No problem, a Y servo harness is a common solution when no port is available. Most decent shops should have them, especially airplane oriented ones.
Dave H is offline
Old 12-17-2013 | 11:00 AM
JimmyG's Avatar
No I didn't dave. When I got the transponder, I didn't have a chance to install it until I was at the track, then when the truck wasn't working, I started to wig out. I have a Futaba 3 channel receiver, and was used to using the bind port for the hybrid, I just naturally picked that port. I have it in the channel 3 port and it is fine.
JimmyG is offline
Old 12-17-2013 | 02:06 PM
racer1812's Avatar
Super Moderator
I never even thought about he RC4 and it being 3 wire. Makes sense that it won't work and put the receiver into bind mode, if you try and use the bind port. Thanks for clearing that part up.
Old 12-18-2013 | 04:06 AM
Yes, thanks Jimmy. Does anyone know what the 3rd wire does? If I remember MyLaps said the RC4 offered temperature measurement, but I assumed that was transmitted wirelessly to the loop? Will there be some future box like some of the radio telemetry systems for it to work with??
Can the 3rd wire be eliminated/bypassed, and still get lap counting?
Dave H is offline
Old 12-18-2013 | 06:24 AM
JimmyG's Avatar
The speculation is, the 3rd wire is for MyLaps to program the transponders for the unique id's or if you want multiples of the same number. So you can order 9999999-1, 9999999-2 etc..
JimmyG is offline
