The AE FActory Team B44.2 Thread >
Old 11-12-2013 | 03:53 PM
  #6166
fq06's Avatar
What are those made of? A felt kind of stuff like the stock pads? They don't say other than FCS... Fiber Composite Stuff?
Interesting to note they also sand the pads
fq06 is offline
Old 11-12-2013 | 08:24 PM
  #6167
Originally Posted by Waflet
Hideeho
You need:
http://www.avidrc.com/product/5/acce...cessories.html
or you can spend more money buying a whole bunch of parts that won't handle as well or be as easy to drive on 99% of the tracks out there.
I run on a low bite clay track
xTotalghost is offline
Old 11-12-2013 | 08:35 PM
  #6168
Hideeho
You need:
does the avid chassis set really make that much of a difference?
fivepointnine is offline
Old 11-12-2013 | 08:45 PM
  #6169
I have no idea.
Old 11-12-2013 | 09:27 PM
  #6170
froggie22's Avatar
Simple answer, Yes it does.
If you spend any money on the buggy, spend it on the Avid chassis.
And you will notice a significant difference on a low bite clay track as well. That is what I run on.
froggie22 is offline
Old 11-12-2013 | 09:32 PM
  #6171
can you expand on how it helps?
Old 11-12-2013 | 11:25 PM
  #6172
I was told that It wouldn't preform well on our low bite track, but then you have people running the c4.2 which is made for high bite tracks. Can you tell me what it helps? Is the weight lower to the ground hair plant it better?
Old 11-13-2013 | 03:15 AM
  #6173
The B44.2 has been out for about a year now.
Should we be expecting a B44.3, or a B45 or ...?
kevinrc is offline
Old 11-13-2013 | 12:43 PM
  #6174
rifleman223's Avatar
Only difference between the 44.2 & .1 is it's 8mm longer & has 12 mm BB shocks .
If you race indoor the 44.1 is still a great ride....
Just install the 12mm shock and your all good ...
I beg to differ. Parts that differ
1. Longer rear deck
2. Longer slipper shaft
3. VTS Slipper
4. Longer rear dogbone
5. Shocks
6. Battery holders (ok this is trivial)
7. Body of course
The longer chassis and shocks make the car more stable but sacrifice a little in the turn in. But that can be mitigated by setup.
rifleman223 is offline
Old 11-13-2013 | 12:47 PM
  #6175
yes, it makes the car stiffer so the suspension and setup really works better. The decreased mechanical traction from the stiffer chassis makes the car handle much better.
Old 11-13-2013 | 12:53 PM
  #6176
+1. maybe comes standard with an aluminum chassis, option for gear diffs, stronger a-arms?
Eaglesrx is offline
Old 11-13-2013 | 01:11 PM
  #6177
these look sick, i want one
davy1317 is offline
Old 11-13-2013 | 01:43 PM
  #6178
FWIW, in regards to upgrading from a .1 to .2.
I am currently running a PL Bulldog body for the .1 on my .2. Not real sure how much of a difference there is "supposed" to be, but mine fits well.
NitroOB4You is offline
Old 11-13-2013 | 02:10 PM
  #6179
Wild Cherry's Avatar
1. Longer rear deck
3. VTS Slipper
5. Shocks
7. Body of course
The longer car was just marketing gimmick ..
Quite few of our local Ae drivers including me still use the short chassis ....
Wild Cherry is offline
Old 11-13-2013 | 02:13 PM
  #6180
t0p_sh0tta's Avatar
Same here, just shim the rear body mount forward ~4mm.
If I had a 44.1, I'd throw on a Triad, and some big bores and call it done. Hell, I'd probably trade my .2 for a properly maintained .1.
t0p_sh0tta is offline
