Xray X1 - Formula One Car >
Like Tree366Likes
Old 04-13-2026 | 12:48 PM
  #3331
Looking for a upper front x1 23' wide arm plate P#371069
toepush is offline
Old 06-07-2026 | 08:21 PM
  #3332
RCBuddha's Avatar
This is going to sound weird, but I can't find a left side hub for the rear axle. Has anyone tried a left side hub from exotek? Maybe another brand?
RCBuddha is offline
Old 06-08-2026 | 02:54 AM
  #3333
I have the Team Saxo one on my '21. I did have to shave down the portion on the bearing side slightly to make width with the Excelerate tires, but that wasn't terrible to do.
interstatehobby.com/products/team-saxo-wheel-stopper-6-35mm?_pos=4&_sid=1a71ddaa9&_ss=r
ricerscott is offline
Old 06-08-2026 | 06:25 AM
  #3334
They all work, CRC, Exotek, etc. just the spacing required to get the correct width / axle spacing from the rear axle bearing to the outer edge of the hub will vary. As long as you have available, or order a variety of rear axle shims, especially 1.0, 0.5, and 0.25mm shims, you will be good, and as stated above, some may be a little wider.
I'm running the Exotek rear hubs with the CRC rear axle on my eXcelerate F1. If I still owned an XRAY X1 and needed to replace the axle and/or hubs, I would not replace the axle or hubs with XRAY parts. An XRAY replacement solid axle is $103, left hub $48, for $151 total, while you can buy a CRC axle and two Exotek hubs for $70.
kn7671 is offline
Old 06-08-2026 | 07:07 AM
  #3335
RCBuddha's Avatar
Thanks for the link, I just ordered!
Thanks for confirming! I figured it would just be a spacing issue. It’s so strange that none of the usual online shops that I use have the Xray left side hub in stock. I was originally trying for the Team Saxo diff but that’s out of stock as well.
RCBuddha is offline
