The AE FActory Team B44.2 Thread >
Old 10-18-2013 | 05:25 PM
  #5926
So I got my conversion kit from Bugle Boy, and I went to build my durango gear diffs...
Durango included the wrong size bearings with both gear diff kits. WTF
ntJeff is offline
Old 10-18-2013 | 06:14 PM
  #5927
fq06's Avatar
I have not installed the gear diffs so I'm flying blind but the Durango bearings are metric and the AE housing is standard. I think the bugle boy kit comes with a spacer to take up the gap between the bearing and the housing right?
Even with that spacer, shim whatever it is not the right size?
fq06 is offline
Old 10-18-2013 | 06:19 PM
  #5928
The bearings included w/ the gear diffs aren't the ones that are supposed to be included. They don't even fit onto the diff housing or over the outdrive. They're not the part # that is shown on the little instruction manual.
The bugle boy kit does come w/ spacers to make up difference between the bearing and gearbox housing, but my build came to a screeching halt.
ntJeff is offline
Old 10-18-2013 | 06:21 PM
  #5929
fq06's Avatar
Oh, that sucks.
If the Durango bearings don't fit on the Durango diffs, they obviously packed it wrong
fq06 is offline
Old 10-19-2013 | 04:13 PM
  #5930
elex300's Avatar
Delete
elex300 is offline
Old 10-20-2013 | 04:37 AM
  #5931
daverobbo5's Avatar
Default Racing with associated cars today
Originally Posted by rdeppen
Avid shock mount bushings, Grey front, Green rear springs and Machined shock pistons from GHEA, AE or Avid. The kit molded pistons have way to much blow by. Machined pistons just make the shocks work better. I like the 4 hole Avid 2+2 pistons. 1.5x1.1 fronts and the 1.6x1.1 rear. 35frt 32.5rr cars works awesome outdoors
so it stands to reason that the ghea pistons fit the shock body more precisely/ tightly and still have the same hole diameter.
using 30 weight in B4.X and B44.X there was way too much pack. then dropped to 25 weight oil simply too much pack as there was no "blow by"
I think someone called the oil that would pass by the side of the moulded associated piston, "blow by".
so without the blow by and using these pistons i'd have to drop to 22.5 or 20 weight oil.
bummer- got plenty of 25 and 30 weight. not keen to buy more oils at the moment.
fact it that I still saw guys with 'out of the kit' B4.X and B44.X going faster. this upgrade might have to go into the 'waste of r/c dollars??' thread
any ideas ghea piston people???? thanks in advance.
daverobbo5 is offline
Old 10-20-2013 | 04:57 AM
  #5932
mgtmadness2007's Avatar
What would it take too turn this into a short course truck?
mgtmadness2007 is offline
Old 10-20-2013 | 06:02 AM
  #5933
Whatever it would take for you to sell it and use the proceeds to buy a short course truck!
Seriously, there would be no practical path I see to get there. No readily available longer chassis or arms, and even if you some how made that work you would want to put gear diffs in and that's another $180 sourcing from Bugle Boy.
34x17 is offline
Old 10-20-2013 | 07:55 AM
  #5934
ryanpatrickgore's Avatar
Very few new setups Have been posted lately. For medium-high bite clay Are you guys still running the same piston package as last year? 1.6 fronts and 1.7 rear pistons?
ryanpatrickgore is offline
Old 10-20-2013 | 08:09 AM
  #5935
tony montana's Avatar
would like to know myself. Our track is medium traction and somewhat tight
tony montana is offline
Old 10-20-2013 | 08:08 PM
  #5936
Got to hit the track today, man is this buggy freaking sweet.
One thing though, after a 6min max run, I was 190 on the motor, and 160ish after another run. Geared 18/81, zero timing on a 6.5
Why so hot?
ntJeff is offline
Old 10-20-2013 | 08:28 PM
  #5937
Guest
Why so hot?
Maybe more rotating mass???? My guess???? Do the gear diffs bind at all?
kyoshoracer77 is offline
Old 10-20-2013 | 09:13 PM
  #5938
fq06's Avatar
Why so hot?
Motor bearings are good? No binding anywhere in the drivetrain with the motor backed off so all you feel is drivetrain resistance? Gear mesh is not too tight?
Thats warm. My 6.5t with 15° of esc timing after 10+ minutes I come off at 145°. That's with 19/81 gearing.
fq06 is offline
Old 10-21-2013 | 01:02 AM
  #5939
ktorpil's Avatar
I have a race coming in December at Northern Cyprus and I am thinking about getting aluminum A arms. I know, I know...But wait a bit before yelling "Blasphemy!" at my face.
Along with GPM front & rear (they are a great deal together and you cannot get just the front ones anymore) a arms, I will also be buying these:
http://www.hot-racing.com/index.cgi?...=BFF0801;c=417
and these:
http://www.hot-racing.com/index.cgi?...=BFF0901;c=417
I already have the AVID chassis so I think I will be good in hard landings. I know I'm not a seasoned racer but I'm fairly competent and I just don't go hitting stuff at full speed.
So I'm really thinking about getting these until at least RPM comes up with a design. What do you think?
ktorpil is offline
Old 10-21-2013 | 03:06 AM
  #5940
hesh's Avatar
Stockup on bulkheads if you get those...
hesh is offline
