The AE FActory Team B44.2 Thread
#5927
I have not installed the gear diffs so I'm flying blind but the Durango bearings are metric and the AE housing is standard. I think the bugle boy kit comes with a spacer to take up the gap between the bearing and the housing right?
Even with that spacer, shim whatever it is not the right size?
#5928
The bearings included w/ the gear diffs aren't the ones that are supposed to be included. They don't even fit onto the diff housing or over the outdrive. They're not the part # that is shown on the little instruction manual.
The bugle boy kit does come w/ spacers to make up difference between the bearing and gearbox housing, but my build came to a screeching halt.
#5931
Avid shock mount bushings, Grey front, Green rear springs and Machined shock pistons from GHEA, AE or Avid. The kit molded pistons have way to much blow by. Machined pistons just make the shocks work better. I like the 4 hole Avid 2+2 pistons. 1.5x1.1 fronts and the 1.6x1.1 rear. 35frt 32.5rr cars works awesome outdoors
using 30 weight in B4.X and B44.X there was way too much pack. then dropped to 25 weight oil simply too much pack as there was no "blow by"
I think someone called the oil that would pass by the side of the moulded associated piston, "blow by".
so without the blow by and using these pistons i'd have to drop to 22.5 or 20 weight oil.
bummer- got plenty of 25 and 30 weight. not keen to buy more oils at the moment.
fact it that I still saw guys with 'out of the kit' B4.X and B44.X going faster. this upgrade might have to go into the 'waste of r/c dollars??' thread
any ideas ghea piston people???? thanks in advance.
#5933
Whatever it would take for you to sell it and use the proceeds to buy a short course truck!
Seriously, there would be no practical path I see to get there. No readily available longer chassis or arms, and even if you some how made that work you would want to put gear diffs in and that's another $180 sourcing from Bugle Boy.
#5935
#5938
Thats warm. My 6.5t with 15° of esc timing after 10+ minutes I come off at 145°. That's with 19/81 gearing.
#5939
I have a race coming in December at Northern Cyprus and I am thinking about getting aluminum A arms. I know, I know...But wait a bit before yelling "Blasphemy!" at my face.
Along with GPM front & rear (they are a great deal together and you cannot get just the front ones anymore) a arms, I will also be buying these:
http://www.hot-racing.com/index.cgi?...=BFF0801;c=417
and these:
http://www.hot-racing.com/index.cgi?...=BFF0901;c=417
I already have the AVID chassis so I think I will be good in hard landings. I know I'm not a seasoned racer but I'm fairly competent and I just don't go hitting stuff at full speed.
So I'm really thinking about getting these until at least RPM comes up with a design. What do you think?
and these:
