NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 09-19-2013 | 03:37 PM
  #11236
COBRARACING's Avatar
Originally Posted by sleenad
Hey Angelo,
just wanted to thank you for helping me out with the ini files on the v2.1 speedo. All is great now and I can switch to whatever firmware I want.
Thank you for your kind words .All we can do is our best
COBRARACING is offline
Old 09-19-2013 | 08:19 PM
  #11237
Nuno Gancho's Avatar
So after installed a new speedo same problem, after testing conclusion on that precise moment the turbo was kicking in and messing up with the brake now all OK. Thanks.
Nuno Gancho is offline
Old 09-20-2013 | 05:37 AM
  #11238
Friends, help. I researched a bit about Fleta 4, but very little is said about it yet. It is possible to place the software on esc lcd card and the HW?
Pickthall is offline
Old 09-21-2013 | 07:33 AM
  #11239
ta04evah's Avatar
I believe the Much More Fleta4 is a re branded Speed Passion Reventon Pro. More than likely the software will not work as Hobbywing does not manufacture OEM esc's for Speed passion any more.
Cheers
Rob.
ta04evah is offline
Old 09-25-2013 | 07:19 PM
  #11240
Cheers
Rob.
Correct.
Old 09-25-2013 | 07:22 PM
  #11241
Hi guys
Just a heads up we have a delay on roar approved motors and i dnt have any confirmed release date.You still can buy the first version of the motors but they are not approved roar legal at this stage not saying the first wont be but at this stage they are mot approved.
Old 09-26-2013 | 03:23 AM
  #11242
ta04evah's Avatar
Originally Posted by COBRARACING
Hi guys
Seems like there's a delay at ROAR for other brands of motors along with Hobbywing. Just out of curiosity, does Hobbywing submit their motors for approval with other governing bodies such as the BRCA ?(I think that's the correct body) because in some events here the motors can be approved on other lists to be able to used in said events.
Cheers
Rob.
ta04evah is offline
Old 09-26-2013 | 11:34 AM
  #11243
The BRCA lists for all motors are here if you want to check. HTH
http://www.brca.org/index.php?q=cont...-updates/14218
SlowerOne is offline
Old 09-28-2013 | 09:13 PM
  #11244
Charlie 13's Avatar
Default new 3.1 1S wont connect
I have the new 3.1 1S and it will not connect to the programming box, any quick suggestions on what i could be doing wrong?
Charlie 13 is offline
Old 09-28-2013 | 11:35 PM
  #11245
Madulla's Avatar
You connecting thru the port on the Esc and not using the cable to the receiver? It doesn't connect like the older models.
Madulla is offline
Old 09-29-2013 | 04:08 AM
  #11246
Charlie 13's Avatar
Whoa - didn't know that, I will try, thanks!
Old 10-04-2013 | 08:15 AM
  #11247
Mr.juarez's Avatar
Hello there. I'm currently using a v3.1 in blinkly with a 21.5 motor. I have the punch rate at 30, but my question is my bottom end feels flat compared to my v2.1 what other setting can I alter to get more low end.
Mr.juarez is offline
Old 10-05-2013 | 11:34 AM
  #11248
Any tips on a base setup for a v3.1 1cell?
What firmware is best for 1/12 mod?
I am using 4,5-5,5T Muchmore motors, what rollout and base settings should I use?
chovden is offline
Old 10-07-2013 | 01:15 PM
  #11249
Is it possible to disable the "power off after holding brake for 5 seconds" function on the esc? This functionality means this esc is unusable on tracks that have sloped starting positions where you need to hold brake to stop rolling... It's not good having your car turn off on the starting grid
luda is offline
Old 10-07-2013 | 01:17 PM
  #11250
aloksatoor's Avatar
Don't think its possible. For situations like those, I turn up the initial brake to 25 percent or so. The initial does not affect any other parameters like drag brake etc. So cars pretty solid without throttle kinda like a handbrake .
aloksatoor is offline
