Tekno SCT410 Thread
I need to change my base setups now because of the new chassis/weight loss and also the smoother drivetrain. Will do a test day this weekend I guess.
Sounds good, thanks for the info on the shims since I got my new diff case on its way in the mail.
Hard pack clay high bite 1/8 track the track is very smooth with very large jumps. It also has a washboard section ( very rough section ) and I can go through at full speed and stay perfectly in control. I'm running stock pistons with 45frt and 40rr and 5-5-3 in the diffs. Very dialed. Just started using the jc high flow body but will be going back to the tundra for durability because my brand new jc is already starting so crack in the corners. My tundra bodies have lasted me a good while with no issue
I have a question for you guys. Where are you guys mounting your ESC's on/off switch at on your truck? I am running the side air guards so I have mine on the guard but I am looking around and don't know where else I can put it if I take off the guards. So right now that is preventing me from taking the guards off even just to see the difference in feel without them. I run the RX8g2
Also, extension wire against the servo for the transponder
17Likes
