Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 09-23-2013 | 06:28 PM
  #1186
XRated SCT's Avatar
What's the percentages for current limit tuning on the esc without Hotwire
XRated SCT is offline
Old 09-23-2013 | 06:57 PM
  #1187
RiceP's Avatar
Ok found that I had the esc in bl fw/rv moved it to bl dl think this is brushless with delayed reverse hope this helps. But I was wanting to look at the setups on tekin site for the rx8 gen2 with the 4300kv pro4 but when I pull it up it opens but unreadable format what do I need to open in.
RiceP is offline
Old 09-23-2013 | 07:25 PM
  #1188
slashracer111's Avatar
Originally Posted by Randy_Pike
No, the board layout is different and thus the housing is different as well.
Thank you for the answer, Mr. Pike.
slashracer111 is offline
Old 09-23-2013 | 07:26 PM
  #1189
fq06's Avatar
Yeah, brushless delay is what you want.
I think the links now downloading the ESC setup to your hotwire files now so you just open it in hotwire and apply. They used to be a PDF, but now it loads the actual setup for you.
If you look, the link is not in the PDF column, it's in the profile column. Nothing in the PDF column.
http://www.teamtekin.com/hotwire/ESC...up-sheets.html
fq06 is offline
Old 09-23-2013 | 09:30 PM
  #1190
slammedwagon's Avatar
hey guys looking at getting a new RX8 Gen2 and just wanted to know if they still have that common fault of catching fire after a hard impact.
slammedwagon is offline
Old 09-23-2013 | 09:38 PM
  #1191
fq06's Avatar
Here's the quick tune menu that also shows the default settings, CL is none.
fq06 is offline
Old 09-24-2013 | 04:14 AM
  #1192
XXXDad's Avatar
Thumbs down Problem with PDF on Tekin site
I am also having problems viewing PDF from Tekin site
XXXDad is offline
Old 09-24-2013 | 06:44 AM
  #1193
fq06's Avatar
There are pdf's for RX8 but only profiles for RX8 gen2. No PDF to see from what I can tell.
fq06 is offline
Old 09-24-2013 | 07:33 AM
  #1194
Integra's Avatar
Never did the Rx8's have an issue with catching fire, Ya sure the odd one might go up, But Overall Ive seen FAR more CC's go up in smoke than Tekin, As a matter of fact ive never actually seen a Rx8 Melt down due to normal Running circumstances.
Integra is offline
Old 09-24-2013 | 02:06 PM
  #1195
justpoet's Avatar
The "land hard and catch fire" issue was with the original RX8, if I remember correctly. That was pretty much fixed with the 3 hole case revision, and Tekin stated they had even further protected against hits with the Gen2. I think we should be good there.
justpoet is offline
Old 09-24-2013 | 10:11 PM
  #1196
I asked pretty much the same question with no results. My best guess would be
LM 1 = 0%
LM 1-2 = 8%
LM 2 = 17%
LM 2-3 = 25%
LM 3 = 33%
LM 3-4 = 41%
LM 4 = 50%
LM 4-5 = 58%
LM 5 = 66%
LM 5-6 = 75%
LM 6 = 83%
LM 6-7 = 91%
LM 7 = 100%
sam1950 is offline
Old 09-24-2013 | 10:16 PM
  #1197
Randy_Pike's Avatar
Team Tekin
The Rx8 Gen2 setups are direct download files, not pdf's hence the reason you can't read them.
You can use RX8 Gen1 setups in the Gen2 and 99% of the setup features will work.
Randy_Pike is offline
Old 09-25-2013 | 05:05 AM
  #1198
hey guys I just had my first tekin failed how do I go about claming my rx8 gen 2 under warranty as I brought from tower hobbies
RavensNightFury is offline
Old 09-25-2013 | 09:22 AM
  #1199
Default Just wondering.
On the Tekin website is states:
"Tekin recommends LiPo batteries with at least a 40C discharge rate for 1:8 applications."
What could or would happen if you used LiPo batteries with less the 40C?
Scooter72 is offline
Old 09-25-2013 | 09:37 AM
  #1200
MonsterSummit's Avatar
Nothing from my experience. I have ran a ton of 20c 4s batteries for practice runs before. Never had an issue. Anymore I use a 55c, not because I thought I had to, just because its what I bought.
MonsterSummit is offline
