Team Associated B4.2 Thread >
Like Tree4Likes
Old 09-21-2013 | 07:46 AM
  #9586
Waflet's Avatar
Originally Posted by Rob Braz
Could someone explain to me what a shaved u brace is and c hubs? Thanks
Hideeho
See page 1.
Waflet is offline
Old 09-21-2013 | 06:00 PM
  #9587
Wild Cherry's Avatar
First Try Out
The new HARD rear arms feel or perform the same as the carbon version.
Can't notice a significant difference.
They fit great, tight & smooth.
The new rear Hards will make a big improvement for the B44
The carbon arms sway bar studs were in the wrong location for the B44.
Wild Cherry is offline
Old 09-21-2013 | 06:34 PM
  #9588
Originally Posted by bds81175
My son painted his. Did you paint yours on the outside? Can't tell from the pics but it looks sharp painted on the inside.
Both inside & outside are painted the same. Couldn't get the desired look by painting inside only. Painting both sides will also prevent any clear spots from bad landings (I do those a lot )
ntJeff is offline
Old 09-21-2013 | 07:00 PM
  #9589
DBell79's Avatar
Default Differences
Could someone tell me the differences (if any) there are between the B4.1(Worlds car with big bores) and a B4.2?? I'm just looking for advice before purchasing a 1/10 2wd buggy to get back into this great hobby! Thanks in advance!!
DBell79 is offline
  #9590
silveraider14's Avatar
Ran my 4.2 on our outdoor carpet track and it was a handful. Just being rear motor it had nothing on the mid motors. Not really a suprise but coming from a rb6 mm it was super inconsistent. Although the 3 x 1.4 pistions are dialed!
going to race indoor dirt tommarow with those hard rear arms also! Wish I would have got to try them on the carpet tho
silveraider14 is offline
Old 09-21-2013 | 07:12 PM
  #9591
Cridd's Avatar
http://www.amainhobbies.com/product_...-2x16mm-2x11mm
anybody tried these?
Cridd is offline
Old 09-21-2013 | 07:50 PM
  #9592
Grasschopper's Avatar
Hexes, alloy bellcranks, VTS slipper and a different body on the B4.2
Grasschopper is offline
Old 09-21-2013 | 07:53 PM
  #9593
Originally Posted by Cridd
Yea I run them...I'll be honest though and say I haven't done back to backs like Cherry and I suck so I can't really give good feedback anyway.
Old 09-21-2013 | 08:08 PM
  #9594
DBell79's Avatar
Thanks so much!!
DBell79 is offline
Old 09-21-2013 | 08:56 PM
  #9595
trixter91's Avatar
Also the b4.1 has the front bearings in the wheel or rim where the b4.2 has them built in the front hub.
trixter91 is offline
Old 09-21-2013 | 09:06 PM
  #9596
Is the avid centering kit worth getting?
Madman1 is offline
Old 09-21-2013 | 09:09 PM
  #9597
trixter91's Avatar
I got it I think it helps you jump flatter then off balanced. But anyway for 28 bucks you cant go wrong, if nothing else it gives you a little more weight in the rear.
Old 09-21-2013 | 09:16 PM
  #9598
Does it really help because last race I had a problem with coming off jumps in balanced
xTotalghost is offline
Old 09-21-2013 | 09:18 PM
  #9599
trixter91's Avatar
Yea I would buy it again. Im gonna put it in my sc10
Old 09-21-2013 | 11:00 PM
  #9600
t0p_sh0tta's Avatar
It's not because of the motor being off center. Take a look at everything else first. Make sure shocks are the same length, droop is equal and there's nothing binding.
Bet you $10 that solves if the problem.
t0p_sh0tta is offline
