The AE FActory Team B44.2 Thread >
Old 09-07-2013 | 09:55 PM
  #5311
vfrninja's Avatar
Originally Posted by reo
WOW what a great idea.I didn't think you could convert a B44 to B44.2.Is there a parts list on line. Is it worth while to do a conversion or should I just buy a new kit.Thanks for the idea vfrninja.
There is a list on rc10.com in the b44.1 section, but you don't need all that stuff they list. I just got the avid chassis, +8 kit, ballast weights, and triad. Already had all the avid springs. The front arms are reinforced for the .2 and shock towers are .5 mm thicker up and clearanced for the bb shocks.
vfrninja is offline
Old 09-07-2013 | 09:56 PM
  #5312
vfrninja's Avatar
Originally Posted by rcracer207
I have been having trouble with my rear diff the past two weekends. After running a couple heats my rear diff keeps loosening up on me by the time the main comes. I completely lose all rear drive and end up running around with front wheel drive. I have completely disassembled the diff twice now, each time this has happened and there is absolutely no visible wear on anything. I am loosening the bolt about an 1/8 turn from all the way tight. I have been running the buggy every weekend since April and never had any problems but now this is happening every weekend.
Any thoughts?
Do you have the diff nut on the left and diff screw and thrust on the right?
vfrninja is offline
Old 09-08-2013 | 04:45 AM
  #5313
rcracer207's Avatar
Ya. Ive double and triple checked that Ive built it right.
Racing in a couple hours so well see if it holds up today or if it loosens up again.
rcracer207 is offline
Old 09-08-2013 | 06:35 AM
  #5314
hesh's Avatar
If it loosens again either get new bolt n nut or just put a small dab of blue loctite on it.
hesh is offline
Old 09-08-2013 | 08:04 AM
  #5315
Anyone else having problems with wheel nuts coming off? I've ran 5-6 battery packs through mines and everytime my wheel nuts are coming off.
Associated4434 is offline
Old 09-08-2013 | 09:15 AM
  #5316
I've had the same issues in the past. Now I like to put a little loctite on the axle threads every few weeks. Problem solved.
bcooper is offline
Old 09-08-2013 | 09:24 AM
  #5317
Wild Cherry's Avatar
did you check it using the drivers to lock & torque the gear by hand ?
Wild Cherry is offline
Old 09-08-2013 | 11:59 AM
  #5318
Jmuck69's Avatar
The stock wheel nuts are crap. Invest in some serrated nuts such as tenJconcepts ones. Digs into the wheel and holds.
Jmuck69 is offline
Old 09-08-2013 | 04:58 PM
  #5319
rdeppen's Avatar
I agree the Jconcepts wheels nuts are a worthwhile investment on any 1/10th car. Even when they get old they still have a good bite and don't come off.
rdeppen is offline
Old 09-08-2013 | 05:54 PM
  #5320
Maifield was running the avid chassi at the clash! He's using a lot of avid stuff I wonder why he's not sponsored by them is he?
FastRacer21 is offline
Old 09-08-2013 | 06:03 PM
  #5321
silveraider14's Avatar
I don't think he will be sponsored by avid cause jc makes some of the stuff avid makes so it might conflict
silveraider14 is offline
Old 09-08-2013 | 06:30 PM
  #5322
skrichter's Avatar
Default Maifield Chassis
What do we have here? Definitely not a carbon fiber stock chassis.
skrichter is offline
Old 09-08-2013 | 06:39 PM
  #5323
rdeppen's Avatar
I wouldn't doubt it being an Avid chassis anodized black.
rdeppen is offline
Old 09-08-2013 | 06:40 PM
  #5324
trutledge83's Avatar
Originally Posted by skrichter
What do we have here? Definitely not a carbon fiber stock chassis. And its not Avid either.
Looks like a black avid chassis to me....
trutledge83 is offline
Old 09-08-2013 | 06:51 PM
  #5325
I spoke to maifield at the clash. Its an avid chassis he is running because it just felt better on the track there, He spray painted it black lol.
