Official Tekin RX8 GEN2 ESC Thread
#856
Guys if you're having com problems with the port I'll ask you what type of computer you're using? If it's a laptop or netbook make sure that ONLY the Hotwire is plugged into a USB port, any USB port. Some of the laptops/netbooks don't provide much power via the USB's and if more than one is plugged in at any given time the lack of voltage can cause com issues. Something we saw at the Nats on a guy who had all 4 ports on his laptop "working."
If you had a failure I'd also like to know this info:
Car:
Battery:
Connectors:
Motor:
Gearing:
Settings:
Car:
Battery:
Connectors:
Motor:
Gearing:
Settings:
It's not a powering the Hotwire issue, it's a connection into the fan port issue. If you gently wiggle the Hotwire adapter at the fan port you can see the rx8 LEDs turn on and off.
Scte 2.0
Gforce 2s 6000mah 70c
4mm bullets
Pro4hd 4300
14/40
72% current limit
6.8v cutoff
Neutral width 5
Min throttle 1
Stock timing (10*)
Brakes 100% (40% on tx)
No drag brake
Everything else stock
#857
There is nothing to clear. It doesn't save any data. I try to clear it before I run it and it still has no data after I bring it back in.
Scte 2.0
4mm bullets
Pro4hd 4300
14/40
72% current limit
6.8v cutoff
Neutral width 5
Min throttle 1
Stock timing (10*)
No drag brake
Scte 2.0
4mm bullets
Pro4hd 4300
14/40
72% current limit
6.8v cutoff
Neutral width 5
Min throttle 1
Stock timing (10*)
No drag brake
#858
does the throttle graph in the data logger show how high your throttle is going, if so mine keeps stopping at like 86% or so, I have re-calibrated several times with everything set back to 100 and 0 %, will the nutrel width effect this as I am running around 50 like the rx8 setting but I saw that gen 2 was in the 20's
#860
I have not tried plugging the servo lead into the Hotwire since it is such a tight fit into the rx.
#861
The technical answer is because the standard signal pulse width for RC systems is 1.0ms full brake, 1.5ms for neutral, 2.0ms for full throttle. Our scale is based on these numbers 100/-100. Some radios are 50/50 and some radios are 70/30 and move the neutral down to 1.3ms to give you more resolution on the throttle side.
With your EPA set at 100% the radio appears to be giving us around 1.9ms for full trigger. If you increase the EPA you can get it to 100 or even higher. At max EPA most radios are above 2.0ms. In any case we will flash all the leds and give full throttle/brake if we are calibrated to the radio output.
Sidenote... some radios will drift as batteries get low or due to sitting in hot sun. You can radio calibrate and then turn the radio EPA up 5 or 10 to make sure you always get to full throttle.
#862
So to test this, unplug the Rx8 from the receiver, this will cause the fan to run all the time, now test the port. Result?
#864
You will be charged the "non warranty" replacement cost for the Rx8 Gen2 swap.
#867
#870
The short answer is that it does not matter because we calibrate to the end points and neutral so they are correct and you get full throttle and brake.
20Likes
