Official Tekin RX8 GEN2 ESC Thread
#1609
I just bought a Serpent 811 BE 2.0 and I will be running a Tekin RX8 Gen 2 with a Tekin 1900 kv. Track I plan on running is an outdoor , not very good traction, not very technical has a 125' straight.
Can anyone suggest a good Tekin ESC setup to start?
I plan on running the stock setup for the Serpent to learn the buggy.
Any recommendations or suggestions would be greatly appreciated.
#1611
So is it correct that current limiter only tames the acceleration and not the top end/speed? I also have my timing at 0. Would it be good to try and run a few degrees of timing? I have rx8/ 1900. It runs fine but I am just trying to get ideas on how I may be able to dial it in more precisely.
#1612
I can get 10-12 on a 5000mah if I'm smart but if I drive like a pissed off teen ager forget it lol...
#1613
And no the esc comes with the Hotwire adapter.
#1614
Ok thanks. Another question, I just put new bearing in my motor. While I had it apart I added a shim in front of the rear bearing because my motor has a lot of play. It took most of the play out but I am wondering if the shim will throw anything off inside the motor.
#1615
Are rx8 fires covered under warranty? I am remembering they are from another response on here, but want to be sure. RX8 got toasted after it appears a post came out
luckily it didn't burn anything else except the body...
I was also told Tekin won't be back to work until the 6th, so no processing until then for warranties? I have a race I want to run, but it may be too late then.
luckily it didn't burn anything else except the body...I was also told Tekin won't be back to work until the 6th, so no processing until then for warranties? I have a race I want to run, but it may be too late then.
#1616
No, but make sure there is some play in the motor.
#1617
Sorry to hear that it happened either way though.
We are closed for the holidays however...
#1618
have tried to get it to fail at practice but not happening.
#1619
Hello, I have a question for you ... I have the motor (T8) TT2351 4030 2050kv and I have broken the pcb while trying to change the bearing. I am looking for the pcb replacement but can not find specifically for that engine (T8), there is a compatible pcb?
This is the list that I have, please can you tell me which would be consistent with the T8? many thanks to all.
Tekin Pro4 TEKTT2513 Sensor PCB
Tekin Redline TEKTT2473 Gen2 Sensor PCB
TEKTT2393 T8i Tekin Sensor PCB
ROC 412 TEKTT2613 Tekin Sensor PCB
TEKTT2526 Tekin Pro4 HD Sensor PCB
#1620
20Likes
