Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 08-12-2013 | 11:53 AM
  #856
Originally Posted by Randy_Pike
Guys if you're having com problems with the port I'll ask you what type of computer you're using? If it's a laptop or netbook make sure that ONLY the Hotwire is plugged into a USB port, any USB port. Some of the laptops/netbooks don't provide much power via the USB's and if more than one is plugged in at any given time the lack of voltage can cause com issues. Something we saw at the Nats on a guy who had all 4 ports on his laptop "working."
If you had a failure I'd also like to know this info:
Car:
Battery:
Connectors:
Motor:
Gearing:
Settings:
There is nothing to clear. It doesn't save any data. I try to clear it before I run it and it still has no data after I bring it back in.
It's not a powering the Hotwire issue, it's a connection into the fan port issue. If you gently wiggle the Hotwire adapter at the fan port you can see the rx8 LEDs turn on and off.
Scte 2.0
Gforce 2s 6000mah 70c
4mm bullets
Pro4hd 4300
14/40
72% current limit
6.8v cutoff
Neutral width 5
Min throttle 1
Stock timing (10*)
Brakes 100% (40% on tx)
No drag brake
Everything else stock
BiggieFries is offline
Old 08-12-2013 | 12:09 PM
  #857
Randy_Pike's Avatar
Team Tekin
Scte 2.0
4mm bullets
Pro4hd 4300
14/40
72% current limit
6.8v cutoff
Neutral width 5
Min throttle 1
Stock timing (10*)
No drag brake
Ok, so you may simply have a bad hotwire adapter. Have you tried connecting via the servo lead instead? If you can comm there we can eliminate a few things right off the bat.
Randy_Pike is offline
Old 08-12-2013 | 05:00 PM
  #858
Default full throttle
does the throttle graph in the data logger show how high your throttle is going, if so mine keeps stopping at like 86% or so, I have re-calibrated several times with everything set back to 100 and 0 %, will the nutrel width effect this as I am running around 50 like the rx8 setting but I saw that gen 2 was in the 20's
yellowjacket45 is offline
Old 08-12-2013 | 06:10 PM
  #859
i had the same problem then i plugged the wire that goes to the receiver into the hot wire and worked fine?
ScottZ is offline
Old 08-12-2013 | 11:39 PM
  #860
Tried all 4 of my Hotwire adapters and a buddies. When the fan is plugged in it also cuts in and out if you gently wiggle it.
I have not tried plugging the servo lead into the Hotwire since it is such a tight fit into the rx.
Old 08-13-2013 | 10:26 AM
  #861
Tekin Prez's Avatar
Team Tekin
The short answer is that it does not matter because we calibrate to the end points and neutral so they are correct and you get full throttle and brake.
The technical answer is because the standard signal pulse width for RC systems is 1.0ms full brake, 1.5ms for neutral, 2.0ms for full throttle. Our scale is based on these numbers 100/-100. Some radios are 50/50 and some radios are 70/30 and move the neutral down to 1.3ms to give you more resolution on the throttle side.
With your EPA set at 100% the radio appears to be giving us around 1.9ms for full trigger. If you increase the EPA you can get it to 100 or even higher. At max EPA most radios are above 2.0ms. In any case we will flash all the leds and give full throttle/brake if we are calibrated to the radio output.
Sidenote... some radios will drift as batteries get low or due to sitting in hot sun. You can radio calibrate and then turn the radio EPA up 5 or 10 to make sure you always get to full throttle.
Tekin Prez is offline
Old 08-13-2013 | 12:01 PM
  #862
Randy_Pike's Avatar
Team Tekin
If you're fan is cutting in/out something is wrong. Note that the fan is defaulted to only turn on when the temp requires it.
So to test this, unplug the Rx8 from the receiver, this will cause the fan to run all the time, now test the port. Result?
Old 08-13-2013 | 12:21 PM
  #863
I have some burnt up tekin rx8 gen 1s and on the form to send them in I saw something about upgrade costs. Is it possible to pay a little over the normal replacement cost to upgrade to the new gen 2 rx8?
IOP_Racer is offline
Old 08-13-2013 | 12:30 PM
  #864
Randy_Pike's Avatar
Team Tekin
You will be charged the "non warranty" replacement cost for the Rx8 Gen2 swap.
Old 08-13-2013 | 12:39 PM
  #865
brainiac's Avatar
Could someone link me to info regarding the differences between the Gen 1 and gen 2 motors?
brainiac is offline
Old 08-13-2013 | 01:13 PM
  #866
Randy_Pike's Avatar
Team Tekin
http://www.teamtekin.com/t8_gen1.html
http://www.teamtekin.com/t8.html
Old 08-13-2013 | 01:54 PM
  #867
brainiac's Avatar
So its lighter and smoother pretty much?
brainiac is offline
Old 08-13-2013 | 01:56 PM
  #868
Randy_Pike's Avatar
Team Tekin
Yup!
Old 08-13-2013 | 07:21 PM
  #869
I changed the setting for the fan to always run once it started cutting in and out. Forgot to mention that. Still cuts in and out when wiggled or even when truck is shaken hard
Old 08-13-2013 | 07:23 PM
  #870
Very interesting. Wondered why neutral wasn't zero on mine but it never really mattered since you can see full throttle even if its not 100.
