Team Associated B4.2 Thread >
Like Tree4Likes
Old 08-08-2013 | 10:50 AM
  #7861
Wildcat1971's Avatar
Tech Prophet
ok, lets think about this.
1) take wheel off and feel for it
2) take hex off and feel for it
3) take the pin out and feel for it
4) take the bearing outs and feel them.
Start from the outside and work your way in.
Wildcat1971 is offline
Old 08-08-2013 | 10:56 AM
  #7862
D.Martijn's Avatar
Oke, I'll do that.
While I was spinning the wheel, I noticed this:
quality sucks, because youtube is still processing it..
http://www.youtube.com/watch?v=gS-KYbYxgII
It's like there is some kind of play on the axle and inner ring of bearing.
D.Martijn is offline
Old 08-08-2013 | 11:01 AM
  #7863
D.Martijn's Avatar
I can feel it
Still there..
Still there..
Feel like brand new bearing, which they are.
Old 08-08-2013 | 11:18 AM
  #7864
I can feel it
Still there..
Still there..
replace hub??
derbrylac is offline
Old 08-08-2013 | 11:27 AM
  #7865
D.Martijn's Avatar
Originally Posted by derbrylac
replace hub??
car has done 5 races and some practice rounds..
Still pretty new. also, the bearings fit snug so I think thats not the problem.
Old 08-08-2013 | 11:39 AM
  #7866
What is a proper gearing for the buggy with a 7.5sensored motor?!
theblitzkidd is offline
Old 08-08-2013 | 11:42 AM
  #7867
how much kv?
Cody227 is offline
Old 08-08-2013 | 11:48 AM
  #7868
Matt Trimmings's Avatar
Hey guys,
Anyone there that also runs the Jconcepts axles??
I recently fitted them and it seems there is a clicking noise..
I fitted new bearings and it's the same.. Any suggestions to solve the clicking.. it's driving me insane that stupid noise..
http://www.youtube.com/watch?v=rWLTbV2gLuk
I also posted a message in the Jconcepts thread a few days ago but haven't gotten an answer yet.. since there is a race sunday, I want to get it fixed asap.
I only use 1 shim per axle instead of the 2.
Matt Trimmings is offline
Old 08-08-2013 | 11:50 AM
  #7869
D.Martijn's Avatar
So you can move the axle more towards the outside of the buggy?
And there will be a tad more clearance at the little notch,
I'll might try to do that.
Old 08-08-2013 | 11:53 AM
  #7870
Wattsup23's Avatar
start around 78/22 then gear from there
Wattsup23 is offline
Old 08-08-2013 | 11:55 AM
  #7871
Check how tight you have the hexes screwed down. They should be just snug enough to not come off the axle.
JiuHaWong is offline
Old 08-08-2013 | 12:07 PM
  #7872
Jake S's Avatar
im running 78/20...
Jake S is offline
Old 08-08-2013 | 12:21 PM
  #7873
I can feel it
Still there..
Still there..
How about this keep it lubed..... Does the car do anything wierd when your driving it and you cant feel it when your driving right? If it still spins free just drive it. Sometimes it goes away when after some club racing but its not affecting your car... It does not seem like the axles are the problem. If its the bearing it will eventually get worse and come apart. I bet when you put the wheel on it spins free and comes to a slow stop. If its going clunk clunk as its spinning it cant be the axle. most likely the bearing
Bubonic-X is offline
Old 08-08-2013 | 12:25 PM
  #7874
D.Martijn's Avatar
I didn't run my B4.2 since I got the problem.
I'm going to look further into it in the eve.
Old 08-08-2013 | 01:10 PM
  #7875
ryanpatrickgore's Avatar
Do the yaiba hubs develope slop like the blue ae hubs?
ryanpatrickgore is offline
