Team Associated B4.2 Thread >
Like Tree4Likes
Old 07-29-2013 | 05:50 PM
  #7396
kdub's Avatar
Originally Posted by rdeppen
I've run Kimbrough' AE, Jconcepts and none of them are as quiet as the Avid triad setup and a fresh Robinson pinion.
Tip: Soak the new spurs in a cup of water for 6-8 hours and then dry and run, it will be super-quiet.
kdub is offline
Old 07-29-2013 | 05:52 PM
  #7397
Interested to hear why that makes it quieter? Absorbs liquid?
Team G Racing is offline
Old 07-29-2013 | 06:13 PM
  #7398
Wildcat1971's Avatar
Tech Prophet
that was covered a while back. something about re hydrating the spurs, because the moisture leaves them after time.
Wildcat1971 is offline
Old 07-29-2013 | 07:27 PM
  #7399
BLKXJ96's Avatar
Originally Posted by Autocratic
I run cut AKA foams in almost every tire I have. Makes the tire sit flatter and overall gives the tire more traction.
A few guys at the track were telling me this with the AKA wheels too. Compared to the factory wheels the AKA's are slightly wider.....spreading the tire out giving a wider footprint and more traction. Go figure the shop is out of stock on AKA wheels....
BLKXJ96 is offline
Old 07-29-2013 | 07:29 PM
  #7400
Tech Prophet
how much are you cutting of the aka red?
Old 07-29-2013 | 07:44 PM
  #7401
Jake S's Avatar
thanks for the tip, my car has been alittle loud since i got a new spur.
Jake S is offline
Old 07-29-2013 | 07:51 PM
  #7402
Every other rib is the standard.
Kave is offline
Old 07-29-2013 | 07:52 PM
  #7403
Tech Prophet
to flatten the profile?
Old 07-29-2013 | 08:04 PM
  #7404
Skillz_B's Avatar
They might have confused them with the Avid wheels, thw Avids are slightly wider, and fit better especially if you run the JC axles. I have heard a few people complain the Aka wheels hex adapters are to shallow.
Skillz_B is offline
Old 07-29-2013 | 08:14 PM
  #7405
BLKXJ96's Avatar
No i'm wrong.....it is Avid wheels now that you mention it .
BLKXJ96 is offline
Old 07-29-2013 | 08:20 PM
  #7406
No it softens them up significantly.
Kave is offline
Old 07-29-2013 | 09:42 PM
  #7407
Cridd's Avatar
Changing from the three hole kit caster blocks front 30* caster to the two hole FT 30*.
I was on last lap of the day and clipped another car on the straight and broke my right side caster block, LHS had the two hole ones so putting on now.
Cridd is offline
Old 07-29-2013 | 09:51 PM
  #7408
Cridd's Avatar
Also Amain, Tony Screw kit or Rcscrewz?
Cridd is offline
Old 07-30-2013 | 12:08 AM
  #7409
Skillz_B's Avatar
Are the MIP C-CVD'S worth the money, and do the platic retainers stay on or should they be glued?
Skillz_B is offline
Old 07-30-2013 | 12:28 AM
  #7410
elex300's Avatar
Yes,Yes,No glue needed.
elex300 is offline
