Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-27-2013 | 12:15 AM
  #6466
Kellen Guthrie's Avatar
Originally Posted by Team G Racing
Kyosho & Avid springs are top notch products. Highest quality you can get
Yeah they are awesome kyosho is just too expensive. Kurt from avid is a good guy they're working hard on some cool new stuff!
Kellen Guthrie is offline
Old 06-27-2013 | 03:24 AM
  #6467
Skillz_B's Avatar
Originally Posted by MikeFrazer
I am running 1.6s out of the kit with the kit springs and 32.5 front and 30 rear and it bottoms on the jumps and bounces. The track is indoor clay with high traction. Running 17.5 blinky if that matters. Any suggestions?
Tapered 3x1.4mm Pistons all around
Front
Associated 32.5wt Oil and Green Springs
Rear
Associated 35wt Oil and White Springs
Skillz_B is offline
Old 06-27-2013 | 04:28 AM
  #6468
DanielC.'s Avatar
What battery are you using? for stock racing a shorty pack is the way to go, especially for indoor. It'll jump lighter and be more aggressive. The 1.6's have more pack than the tapered 1.4x3. You can try bumping the front spring to green and running 35/32.5 front/rear respectively. Adding droop (removing travel limiters in the shocks) will allow the car to land better but it will be easier to traction roll on indoor clay. If you're still having issues, try making/purchasing 1.5x2+1.1x2 flat pistons. They control the high speed dampening pretty well.
DanielC. is offline
Old 06-27-2013 | 05:00 AM
  #6469
Run a shorty and you shouldn't have a problem bottoming out. My son and I run 22mm ride height indoor high bite, he with the 1.6 pistions, 30/27.5, kit springs, me 3x1.4 pistions, 35/32.5, kit springs and it's no problem. That's with 7 grams in each rear triangle.
Bump it up to 24mm for outdoor, add another 14grams of weight in the battery tray and again, no problem.
34x17 is offline
Old 06-27-2013 | 07:45 AM
  #6470
Originally Posted by ebay007
is there any one that uses tekin gen2 ESC and 8.5 motor and can share is settings?
i have the hotwire but i dont know what to adjust and why.
any one?
ebay007 is offline
Old 06-27-2013 | 07:58 AM
  #6471
any one?
Maybe you should ask questions about your Tekin products in the TEKIN THREAD.
If you are going to make a change to a setting, you are going to have to post what your motor/esc is doing that you don't like. There are way too many setting changes that can effect way too much stuff for someone to just write out what everything does. Not to mention there is a guide on the Tekin website that gives you a general starting point.
Also, if you are asking these types of questions, you do not need an 8.5
ifuonlyknew is offline
Old 06-27-2013 | 07:59 AM
  #6472
Nicholas Muelle's Avatar
is it normal/a good thing to put weight on the other side of your buggy to compensate for the weight of the ESC? or does it not mater?
Nicholas Muelle is offline
Old 06-27-2013 | 08:23 AM
  #6473
Also curious what others are doing. I tried adding 14g next to the rx and honestly did not notice any difference so I just run without weight right now.
chevmaro is offline
Old 06-27-2013 | 08:32 AM
  #6474
vfrninja's Avatar
Avid 1.5x1.1, 32.5f - 30r ae oil, Avid yellow front and rear = $$$.
Never tried kit springs but the kit pistons have alot of blow by, they don't fit tight in the shock body.
vfrninja is offline
Old 06-27-2013 | 08:39 AM
  #6475
bilster44's Avatar
Originally Posted by onefast8
1st go at center mount electronics.
Not as clean as id like but I managed to get my ESC
receiver and spektrum cap all in the battery tray.
Looks pretty clean to me man...
bilster44 is offline
Old 06-27-2013 | 08:51 AM
  #6476
im asking cos im new to 2wd and to tekin. so i wanted a proven setup to start with.
ebay007 is offline
Old 06-27-2013 | 09:06 AM
  #6477
Cain's Avatar
Honestly I think you may want to get an overview first of what the settings do from the manual, and if that isn't sufficient, post the messages on Tekin's thread.
From there, you will get a better understanding of what the product does setting wise, and then you can have a better handle on what to ask as it relates to your vehicle.
Since you are looking at running mod, to be honest a lot of the features of the ESC you probably won't need. Maybe current limiting to calm down the low end power to be honest.
I don't run a Tekin ESC, but with my Speed Passion one that has similar settings, in general with an 8.5 I don't use the timing, etc. features, mainly the current limiting or similar punch control.
8.5 motors give a lot of pop to the buggy. Now if you were running say a 13.5 in a field of 8.5s, etc, you may find benefits to the features of the esc.
Hope that helps.
Tekin is race quality, so it is proven in that sense.
Cain is offline
Old 06-27-2013 | 09:49 AM
  #6478
rcman182006's Avatar
the losi 56 were money for the small bores, which is what he's talking about. I'd start with 1.6's all around 32.5/30 AE Springs green all around or black front depending on track
Losi or AE oil? also I am assuming its the kit 1.6's pistons?
many thanks for the help
rcman182006 is offline
Old 06-27-2013 | 10:12 AM
  #6479
tedstryker's Avatar
Super clean very nice
tedstryker is offline
  #6480
What battery are you running and batch of springs?
I run similar. Avid Batch 2 Yellow Front, Avid Batch 3 Yellow Rear 32.5/30 oil with shorty two pads rear.
chevmaro is offline
