Team Associated B4.2 Thread
#6017
Caster and ackerman are two different things. Ackerman is the difference of the steering angle between the inside and outside wheel. The inside wheel always has to make a smaller circle, so it must turn a bit tighter. The adjustment for ackerman is made by moving the ballstuds on the steering rack.
#6026
#6029
ok I have a question I thought you had to be able to put a long pack in your car to be roar legal, and AE has there rec under the speed control, I took mine out due to that rule so what's the deal anyone know for sure if that's a rule . thnx
#6030
From what I have been told a car cannot be DESIGNED around a shorty pack per ROAR rules. The B4.2 is designed around a full sized pack, if you choose to place the esc in the battery tray that is a personal modification.
4Likes
