Like Tree5Likes
SC10 4x4 Thread
Old 05-29-2013 | 06:27 PM
  #34291
WC:
What settings are you using on your flow? I copied this from my other post in the electronics sction. Just got one, having an issue....
Flow works with a Reedy Sonic 4.5 550 in an SC10 4x4. Airtronics MX3fG radio
When I first installed the esc, I drove it without calibrating it to the radio. I was excited and curious... top speed was insane, but super hard to drive slow, as 5% on the throttle was more like 50%. Ran 1 pack like this, for kicks. Motor at 140, esc at 89. I then calibrate esc to tx, and turned "initial drive" setting down. Truck had normal low end feel, but now no top speed. Temps were 100/80. Got passed on the straight by a buddy's RTR sc10rs. Bumped "initial drive" back up, messed with EPA settings, and recalibrated, but no more top speed to be found.
What gives?
Do I need to add boost/turbo/timing for some reason? SXX/550 combo did not need this...
maddysdaddy is offline
Old 05-29-2013 | 08:34 PM
  #34292
AJay0722's Avatar
Originally Posted by Ralph289
Can't seem to locate the .5mm #9888 washers for the diff any where, can anybody help ?
THANKS
http://www.nitrohouse.com/05mm-Gear-...m_p_15581.html
This is where I order all my parts from but they are out of stock,
AJay0722 is offline
Old 05-29-2013 | 08:58 PM
  #34293
Gearing question that I'm sure has probably been answered (but too many posts to look through em all)
I'm running a Tacon 96M921 4800kv Turn Rating 2D, 4 pole motor with a Brushless Hobbies LT4(120A) in my SC10-4x4. I'm running a 14T pinion and a 62T spur. Temps on the motor don't exceed 150F and the esc about 90F.
I'm new to offroad scene, use to run 1/4 scale NASCAR asphalt oval back 15 yrs ago so this turning right stuff is kicking my butt lol, Any information, knowledge, and or opinions will be a great help
Liberty Gang is offline
Old 05-29-2013 | 10:08 PM
  #34294
Wild Cherry's Avatar
Originally Posted by maddysdaddy
WC:
What gives?
1st
calibrate the transmitter throttle EPA & brake setting's as in the instructions...
set forward , neutral & brake
After you finish , reduce the brake EPA to around 70% or to taste.
Modes
#1 auto brake = 3
#2 feel = 3
#3 torque Timing = 0
#4 boost timing = 1
#5 boost angle = 0
#6 turbo timing = 0
#7 cut off = 3
motor timing = 20 degree
12 tooth 32 pitch pinion
Wild Cherry is offline
Old 05-30-2013 | 09:57 AM
  #34295
anyone using mmp with tekin sc4x with 2s here?
do you guys think its a good esc and motor for sc10 4x4?
tryandfok is offline
Old 05-30-2013 | 12:16 PM
  #34296
I have new body. It's black, nothing special.
In second pic is my work space.
//WC: lowered servo performing very well, reactions seems little bit sharper
Attached Thumbnails SC10 4x4 Thread-p1013464.jpg   SC10 4x4 Thread-p1013475.jpg
Mirek is offline
Old 05-30-2013 | 12:48 PM
  #34297
Nice shop. Hope to have something like that at home one of these days.
JLinney is offline
Old 05-30-2013 | 01:15 PM
  #34298
Cain's Avatar
You may need an external BEC when using that ESC. Seems to be a common thing to do for it.
Cain is offline
Old 05-30-2013 | 03:21 PM
  #34299
can you tell which bec should i use please?
Old 05-30-2013 | 03:36 PM
  #34300
rjohn929's Avatar
Originally Posted by rippen
The tire of choice seems to be Panther Rattlers (clay) and AKA Wishbones (clay)
Fella's just for the record, I don't yell at the marshalls
rjohn929 is offline
Old 05-30-2013 | 05:09 PM
  #34301
couldn't find the castle thread
i just hooked up my mmp with my ko eurus radio
my problem is the servo glitches (moving left and right slightly by itself)
i did calibrate and bind the radio already
does anyone have this problem before?
Old 05-30-2013 | 06:46 PM
  #34302
TomErickson's Avatar
More research and I have to ask, what issues are there with this truck really. Most of the videos I have found show that driving skills of many of the people are not top level so watching Max Flurer, the Ryans, and some others show that this truck is performing well. I think the biggest thing seems to be that it is so different that anything else that it takes a while to get a set-up right and know what to change to get this truck to perform the best for you.
I think those that drive 4wd Buggy would like the slipper more. 8th scale drivers would want the center diff. I am starting to think that keeping the truck light and managing the weight balance is probably the most critical tuning item.
Since I won't be able to run my car until late June I will be researching every aspect of this truck to prepare for some major testing.
TomErickson is offline
Old 05-30-2013 | 06:47 PM
  #34303
For those that are running light, how many mAH do you run in your batteries? I have two Reedy shorty packs 4000mAH. Is that enough for 5 min qualifiers?
Old 05-30-2013 | 07:10 PM
  #34304
cantrell8's Avatar
I run the 4100 reedy, I can get about 10 to 11 minutes on a pack. Keep in mind I run a 540 2 pole motor. George, runs a 550 with the same pack with no problems. We run 6 min quals and mains. You won't have any problems with the 4000!
cantrell8 is offline
Old 05-30-2013 | 07:25 PM
  #34305
My cutoff with the REEDY shorty has been kicking in @ 9 1/2 min mark.
Out door would be less, maybe 8 min.
