SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 05-18-2013 | 04:44 PM
  #1201
Danny/SMC's Avatar
Company Representative
Not sure when this model will be back in stock. I have a ready date of May 30th from the factory on this model but sometimes they get done a bit earlier.
What are you planning in running the pack in ? The 6500-60C will be back in stock on Tuesday and that pack for the price offers good performance.
Danny/SMC is offline
Old 05-18-2013 | 04:46 PM
  #1202
GeorgePravata's Avatar
Danny just got the saddle packs today best way to charge them. Do I charge them as a whole pack or do I charge them one pack at a time. I'm using a LRP touch.
GeorgePravata is offline
Old 05-18-2013 | 04:54 PM
  #1203
this is gonna go in my sc 10 4x4 with a 4.5 novak . it say 2s for battery so other than that im lost if the 60c will work i will get that instead. for the price of them o just looked up i will take two of the wired deans 6500 60c. if you got them
imrob is offline
Old 05-18-2013 | 05:04 PM
  #1204
Danny/SMC's Avatar
You can charge them either way but if you charge them as a 2S pack you will be charging only once. This is why we supply the adapter with XH balance connector.
Old 05-18-2013 | 05:07 PM
  #1205
So use the plug you gave me and charge them as a whole pack with the balance plug. What amps should I be charging them.
Old 05-18-2013 | 05:08 PM
  #1206
Danny/SMC's Avatar
Best thing to do is to pre-order now and packs are due in on Tuesday and orders will start shipping out on Tuesday.
Best thing to do is to try one of the 6500-60C and see how it does for you. The 4wd SC trucks are hard on packs especially if you have to do 10 minute races.
Maybe some can comment on this pack in this particular application to see if they are having good results.
Old 05-18-2013 | 05:11 PM
  #1207
Danny/SMC's Avatar
Yes that is how most charge them as a 2S pack. Use the jumper wire to connect them in series and use the adapter with XH connector. So you plug the 2mm male balance connector into the 2mm female on the jumper wire.
For charge rates I believe 2C gives a great balance between speed and a good charge. In this case 12 amps would be good as this is just a bit over 2C.
Old 05-18-2013 | 05:29 PM
  #1208
i looked one guy said they will fit but did not mention run times or anything. so unless some one chimes in soon im gonna pre order one as your instruction
imrob is offline
Old 05-18-2013 | 05:32 PM
  #1209
ksarantakos's Avatar
What low voltage cut off do you recommend for 4wd sc 2S? 3.2 per cell ok? I've some are running higher to prevent puffing.
-Kyri
ksarantakos is offline
Old 05-18-2013 | 05:38 PM
  #1210
Ok i orederd the 6500 60 c wired for deans if any one has good idea on how this does in 4.5 sct 4x4 please chim in cant wait to try this stuff out.
imrob is offline
Old 05-18-2013 | 08:42 PM
  #1211
Danny/SMC's Avatar
-Kyri
I believe under 3.4v per cell your going to low. The flight guys who have been using Lipos for many years never use more than 80% of packs mAh. I believe 3.4v per cell would leave around 10 to 20% of the packs mAh left in the pack depending on the amp draw and how accurately the ESC measures voltage.
Old 05-18-2013 | 09:36 PM
  #1212
I'm at Amain hobbies running my new batteries and they are doing great in my caster racing SCT. Thanks to Danny for getting them to me in time
bring it on is offline
Old 05-19-2013 | 04:27 AM
  #1213
Markcuda's Avatar
Danny, thank you for the info. yesterday.
I also will be ordering some 6500/60C with Deans next week.
Markcuda is offline
Old 05-19-2013 | 08:48 AM
  #1214
King DORK's Avatar
Last summer myself and 2 of my friends all ran SC10 4x4 trucks with Tekin Pro4 4600 motors and had no problems making 10 minutes with warm up laps on a 1/8 scale track. We all ran 5100 Nano Tech packs which are garbage compared to the SMC packs. Don't think a 6500 SMC would have any issues whatsoever making that mark.
This summer running the same motor in a new Tekno SCT410 . . . . . . . but with SMC lipos.
King DORK is offline
Old 05-19-2013 | 10:27 AM
  #1215
Anyone take one of these packs apart yet? I had to to replace one of the bullet connectors and I was surprised to find the gauge of wire used was not as advertised. Anyone else run into this or it just an anomaly?
mulepic is offline
