SMC LIPO BATTERY THREAD
#1201
Not sure when this model will be back in stock. I have a ready date of May 30th from the factory on this model but sometimes they get done a bit earlier.
What are you planning in running the pack in ? The 6500-60C will be back in stock on Tuesday and that pack for the price offers good performance.
#1202
Danny just got the saddle packs today best way to charge them. Do I charge them as a whole pack or do I charge them one pack at a time. I'm using a LRP touch.
#1203
this is gonna go in my sc 10 4x4 with a 4.5 novak . it say 2s for battery so other than that im lost if the 60c will work i will get that instead. for the price of them o just looked up i will take two of the wired deans 6500 60c. if you got them
#1204
You can charge them either way but if you charge them as a 2S pack you will be charging only once. This is why we supply the adapter with XH balance connector.
#1206
Best thing to do is to try one of the 6500-60C and see how it does for you. The 4wd SC trucks are hard on packs especially if you have to do 10 minute races.
Maybe some can comment on this pack in this particular application to see if they are having good results.
#1207
For charge rates I believe 2C gives a great balance between speed and a good charge. In this case 12 amps would be good as this is just a bit over 2C.
#1208
Best thing to do is to pre-order now and packs are due in on Tuesday and orders will start shipping out on Tuesday.
#1209
-Kyri
#1211
I believe under 3.4v per cell your going to low. The flight guys who have been using Lipos for many years never use more than 80% of packs mAh. I believe 3.4v per cell would leave around 10 to 20% of the packs mAh left in the pack depending on the amp draw and how accurately the ESC measures voltage.
#1214
This summer running the same motor in a new Tekno SCT410 . . . . . . . but with SMC lipos
11Likes
