RC10B4.1 FT/WC
Old 04-08-2013 | 07:56 AM
  #28486
t0p_sh0tta's Avatar
Originally Posted by Cain
anyone here have the older style pin rims in the rear and bearing wheel front pm me if you would like to sell some. I am looking for rims, yellow preferred but I am open to other colors as well as mounted rear tires in loose offroad compounds and tread patterns. so for example:
- Proline M3 Step Pins
- Losi Big Shot Red Compound
- Losi Ifmar Pins Red Compound
- JConcepts Flip outs Green Compound
etc.
By the way, anyone ever broken there rear toe block and lower plate? I noticed this when doing some work on my car, its like the screw just ripped through both. Never had that happen before.
I have plenty. I'll send you a count and a quote this evening.
t0p_sh0tta is offline
Old 04-08-2013 | 08:32 AM
  #28487
Wildcat1971's Avatar
Tech Prophet
etc.
Well Cain, I just picked up a buggy that came with Pin fronts. All new or like 1 practice run. Most all brand new on JC yellow wheels. There is also a set of brand new JC rear pin wheels and a setup of rear bro codes on yellow wheels. I might not know the exact compound of the tires, the previous owner did mark some of the wheels inside the rim. I know for sure there were some 4 ribs for the front, JC front bar codes, and some others. I am at work and dont have the list if front of me. There was a pair of rips and suburbs for the front, but I might keep those. Unsure atm because I might be selling my personal b4. I probably wont get what I want for it though, lol and will keep it. But I do have some stuff i am clearing out. I have a set of unmounted Bk bar reds and I think a set of pinned tapper pins in pink. I need to double check on those. I can take picks tonight if you are interested.
Wildcat1971 is offline
Old 04-08-2013 | 08:47 AM
  #28488
Looking for help on fitment sizing.
I have an RC10T4.1 which just broke the ball and cup for the rear. When this happened I lost the dogbone due to how much crap was on the ground and unable to locate it.
I am going to buy and replace, but I was wondering if anyone knew if the fitment would work for what I'm looking into.
Here are the specs I found on the stock driveshaft/dogbone
This is a steel Dogbone (also called a Drive Shaft) from Team Associated.
This is a Stock part for:
RC10 GT
RC10 T4
RC10 T4.1
SC10 2wd
Includes:
One (1) Dogbone
Specifications:
Length: 3.5"(89.78mm)
Diameter: 0.126"(3.2mm)
I am looking at one of these. Not sure on the Diameter though. Cant find it.
HSP RC Car Part Front/Rear Dogbone 89.5mm
Item No: 08029
Anyone able to help on the fitment?
yamba6 is offline
Old 04-08-2013 | 08:49 AM
  #28489
Tech Prophet
Item No: 08029
here you go.
http://www.amainhobbies.com/product_...iated-Dog-Bone
Old 04-08-2013 | 08:57 AM
  #28490
I will probably purchase those. Reason I ask, the HSP are only about $4 for 2 of the, which I'd probably buy about 3-4 packs of them so I don't have problems running if the ball and cup break again.
The link you sent doesn't show if its 1 or 2 that you get in the package, but the image I see shows 2 in one package.
edit: Thank you very much for the help!
yamba6 is offline
Old 04-08-2013 | 09:05 AM
  #28491
Tech Prophet
I am sure it is a pair. I would just get the AE OEm ones, as you know they will fit. Not worth saving $2 to only find out others dont work.
Old 04-08-2013 | 09:52 AM
  #28492
Cain's Avatar
thanks. feel free to send me pm's with the wheel and tire info.
Cain is offline
Old 04-08-2013 | 10:33 AM
  #28493
Tech Prophet
will do, some of the tires have AKA red inserts also. So I will try to take a good list tonight for you.
Old 04-08-2013 | 11:47 AM
  #28494
Cain's Avatar
thanks guys!
Cain is offline
Old 04-08-2013 | 03:39 PM
  #28495
5th wheel's Avatar
if you put a small spur and pinion on the b4.1 and move the motor forward 2 or 3 mm
will that make the buggy handle better on the track?? or just what will that do for it.
5th wheel is offline
Old 04-08-2013 | 06:49 PM
  #28496
Tech Prophet
Uploaded with ImageShack.us
ok, here we go. most tires look brand new and the rest are 95% tread.
1-Bro Code Rears with Proline inserts ( these are the only rears)
1-unmarked ribs with black inserts
1-JC grooveys with aka red insert
1-Proline hole shots with aka red insert
1- Barcode with stock insert
2- Barcode with AkA red inserts
1- AKA Vector with Proline Blue Inserts
1- New AE pin yellow rear wheels
1- Unmounted Losi Rear red tapper pin
1- unmount front 4wd front red taper pin
1- trinity blue rear foams
1- NIP bk bar rear red
1- unmounted mystery proline tire. looks like a small pinned hole shot
Old 04-16-2013 | 04:45 PM
  #28497
5th wheel's Avatar
Were the best place to put a shorty pack on the b4 1 running stock 17.5 think I might try one out and lose some weight?
Old 04-16-2013 | 04:49 PM
  #28498
5th wheel's Avatar
Anyone know anything about tank power Lipo packs are they any good? I found a 80c pack for 69 bucks
Old 04-16-2013 | 05:04 PM
  #28499
5th wheel's Avatar
What is a strc u brace?
Old 04-16-2013 | 05:09 PM
  #28500
Matt Trimmings's Avatar
I mount mine a little bit back from middle, i would say to start middle and then move it back and forth to see how you like it.
Never heard of them. I have had very good luck with the Protek packs from AMain hobbies. Pro-Match has a great reputation, others have had good luck with the SMC stuff. Did you mean Trak Power? Haven't heard anything regarding them either.
This:
http://www.amainhobbies.com/product_...race-Gun-Metal
Would stick with the standard plastic. I have never used anything from them but have heard that the aluminum isnt of the highest quality.
Matt Trimmings is offline
