TAMIYA M-06 Thread
#1066
That's fantastic. Are you running on carpet?
Also are your running 1 or 2 degree rear upright?
Also it looks like you're running the standard TRF shocks, not the Mini/short TRF correct?
With the added rear weight / traction, I wonder of i will have to soften the front to add steering.
Originally Posted by Aitutaki
Just wondering what kind of Motorcooler you are using.
#1068
I just use 1 screw to the rear stabilizer mount to hold the fan over the endbell.
Also on my M05 ball diff outdrive, notice there is a metal band to prevent it from splitting open. That metal is just the middle part of a ball bearing that I tore apart.
#1069
Have you found them split open? It's the same light weight material as the TRF416, never had those open.. They distort after a while
There is also a hardened version 54238
http://www.tamiyausa.com/product/ite...oduct-id=54238
#1070
Hi Matthias, thanks for the kind words. My friend (the only other M06 racing in my country) also bought the M06R for the parts. The 10gram wheel weights seem to be helpful in low traction. But if track has good grip it might not be needed.
Finally swapped the R knuckles in rear in the car, and made some maintenance work.
Had to replace the spur gear, was nearly stripped...One question I have: Do you put a grub screw in on the axle, when using alu-uprights? (see pic) The R manual says no, but maybe itīs useful to remove any further play? Or leave it out? Would be curious on your advice guys.
. I usually do it when using plastic uprights.Made some pics for you, noticed I didnīt take some for a long time now.
Iīve also the fan above the middle of the can, as the Carson cup machine has an internal fan on the rotor.
BR, Matthias
#1072
Thanks Joel for the comment on the weights. Will for sure try them during the outdoor season on tarmac. Will see if it brings any advantage next week on carpet...
BR, Matthias
BR, Matthias
#1074
Nice gear cover.. where did you get that?
The gear cover I have is from Eagle Racing, they have top quality parts, as they are a nearly as old as Tamiya, but they sell them rather cheap.
I recently found a good webshop in HK, which sells most of their stuff, otherwise quite hard to get here in Europe:
http://www.broadtech.hk/eagleshop/sh...h&keyword=m-06
The gearcover I have now for 2 years, at the moment itīs not in stock.
Very nice parts are also the Shock towers, as the have the original kit holes plus some steps in between. I have them lying around for quite a while and will built them in next.
Your Alfa looks still nice, I like seeing some "racing marks"!
I guess you have a shelf body, too, so itīs no problem!
I like your color choice a lot!
BR,
Matthias
#1075
#1076
#1077
I downloaded the eps files from brandsoftheworld.com. Then I resized them to fit the body. Biggest challenge was finding someone to print them on clear vinyl.
Shoot me a pm with your email, and I will forward you a file with the Autodelta decals
#1078
We were back to the road course setup last night. I'm still happy with the "R". It was working pretty well and I managed to TQ again. I'm not sure how long that will last though, I think they're gunning for me now.
My M05 wasn't happy unless I was running "M"s on all four corners. Last night I ended up with "S"s all the way around for the main on the M06.
#1079
#1080
121Likes
