Tekno SCT410 Thread >
Tekno SCT410 Thread
Like Tree17Likes
Tekno SCT410 Thread
Old 02-25-2013 | 08:21 AM
  #5716
suby723's Avatar
Originally Posted by sramos420
i run mine LOCKED with that 7955tg servo and ofna horn and no stripped problems
4-6MM is where you want the servo saver.
suby723 is offline
Old 02-25-2013 | 08:33 AM
  #5717
sramos's Avatar
i know, but i like mine locked. its just me
sramos is offline
  #5718
Acill's Avatar
Im running a Spektrum 6040 and the stock plastic arm with the saver at the stock setting. No trouble here and I have quite a bit of track time on my truck now. I just try not to hit poles and pipes.
Acill is offline
Old 02-25-2013 | 08:41 AM
  #5719
BLbound's Avatar
get a hitec 7955tg servo and a ofna 24t horn (like on the first page)......and never look back. i run on my eb48 and sct410.....NO PROBLEMS at ALL!!!! i highly reccomend putting washers under link on bellcrank to assure a level link, this will put less stress on servo and increase longevity!! ..........p.s. if you look, this is what most tekno drivers are running as well, maybe a diff horn but pretty much the same. i'd stay away from the hb horn due to increase stress on servo, i snapped inside middle plastic piece (on 1/8 scale) in servo were output shaft comes thru. replaced middle plastic plate and horn to ofna, and been fine since, and thats an 1/8 scale, so you know that servo can take the abuse. NEVER stripped anything
I ended up ordering an Associated 1015DS servo. I've had zero problems with this servo in my 1/8 & I ordered an aluminum arm just to have just in case .
BLbound is offline
Old 02-25-2013 | 08:42 AM
  #5720
RC*PHREAK's Avatar
my stock horn stripped on the first pack. wasn't a crash, just an awkward landing. a buddy stripped his on the first lap. same thing. no crash, just a weird landing.
RC*PHREAK is offline
Old 02-25-2013 | 08:46 AM
  #5721
Foosmatrix's Avatar
Im running the KO Propo 3mm Aluminum servo arm. Works great. First pic is of the arm itself and the second pic is how I mounted the arm to the servo saver
Attached Thumbnails Tekno SCT410 Thread-ko-arm-sct410.jpg   Tekno SCT410 Thread-ko-linkage.jpg
Foosmatrix is offline
Old 02-25-2013 | 09:01 AM
  #5722
Not just you. I'm running mine locked too with no issues.
MattP is offline
Old 02-25-2013 | 09:03 AM
  #5723
Thumbs up Best body for sct410
Hi i just finsh setup my sct410 but now what is the best body that you all recomend for this truck for outdoor track
BrunoMedeiros is offline
Old 02-25-2013 | 09:04 AM
  #5724
Originally Posted by Slashdrivr
Also broke my 2nd axle in 3 weeks. I'm hoping it's really because I'm running the +3 Assoc rims/wheels and the axles themselves are not a weak point, crashes were not all that bad, just happened to come down on that tire first after trying to triple thru traffic...twice
Plan on eventually switching over to the correct rims but I have a box full of the +3 stuff laying around...
I have a few sets of the +3 Hazard wheels too (from my SC10). Did you have rubbing problems at all on the SCT410? I ordered a set of SCTE wheels with my Tekno order so I'll have those just in case. Just hope I can still use all my +3 wheels still since a couple sets the tires are practically new.
justinco is offline
Old 02-25-2013 | 09:07 AM
  #5725
Any scte body is a direct fit. I'm using the tlr high performance sct body. It looks great but its really thin. Probably going with a jconcepts next.
MattP is offline
Old 02-25-2013 | 09:18 AM
  #5726
Vegatron75's Avatar
I'd say, the method rc hellcat, or the FTW diamondback.
Vegatron75 is offline
Old 02-25-2013 | 09:41 AM
  #5727
Bortzilla's Avatar
Originally Posted by Stealth_RT
FYI for those asking about the weights of the stock vs aluminum sway bar ball ends.
Stock, all four, no setscrews: 7.1 g
Aluminum, all four, no setscrews: 2.5 g
Info added to spreadsheet. Thanks!
Bortzilla is offline
Old 02-25-2013 | 09:51 AM
  #5728
Bortzilla's Avatar
where are your axles breaking off at? In the threads where the locknut goes? At the hole where the pin goes through? Do you have any pictures to share?
Old 02-25-2013 | 10:19 AM
  #5729
sramos's Avatar
+1 on the diamondback
sramos is offline
Old 02-25-2013 | 10:32 AM
  #5730
ChrisAttebery's Avatar
Default APE shock tools
I started a separate thread on the shock tools I'm producing. All further updates will be in that thread.
http://www.rctech.net/forum/electric...l#post11860112
Thanks,
Chris
ChrisAttebery is offline
