Go Back  R/C Tech Forums > North American Regional Forums > Northeast Racing Forum
Radio Control Hobbies & Raceway - Waterbury, CT. >
Like Tree21Likes
Rating: Thread Rating: 3 votes, 1.00 average.
Old 01-28-2013 | 07:13 AM
  #25246
t0p_sh0tta's Avatar
IRH is having their Stator Cup race this Saturday.
Anybody interested in going? I'm in, but I'll probably run the B4. Not comfortable with the Kyosho yet.
Maybe I'll come up today and turn some laps.
t0p_sh0tta is offline
Old 01-28-2013 | 07:31 AM
  #25247
trevcoll's Avatar
Originally Posted by willyb
Great run Trev...you were rock solid the whole race and that finish was awesome. Great call on running stadium, that was a blast...Any interest in running them again on Wednesday?
Heck yeah!
trevcoll is offline
Old 01-28-2013 | 10:47 AM
  #25248
vintage Shu Cat's Avatar
Originally Posted by EricW
I'm using 1.6 pistons and the battery pretty far forward, this worked well before the big bores, I'll move it back and see if that helps. I'm also using 2 degrees of anti squat. Oil is 35 front and 32.5 rear, I'll go thinner in the rear and see if that helps also. Springs are listed above, don't remember off the top of my head at the moment.
Of course I'll make one change at a time and see what works, thanks for the help peeps.
I went with the factory suggested setup for pistons, and then I have the shorty pack pretty far to the rear (lined up with the supports). I have 30wt oil all around and brown springs up front and black in the rear. I would suggest playing weights a little at a time, adding weight to the front as needed for steering.
I will meet you at the track tonight if you decide to go practice, and compare notes.
So far, I love the big bore shocks and would suggest try tuning first before you go back to the V2 shocks.
vintage Shu Cat is offline
Old 01-28-2013 | 11:28 AM
  #25249
Change of plans, we'll be open tonight. At the time of the post, the weather was looking really bad.
See you guys there.
n_kosciuszek is offline
Old 01-28-2013 | 11:41 AM
  #25250
t0p_sh0tta's Avatar
I plan on going tonight as well. You guys are free to try my car if you'd like, but I'll warn you now. It has TONS of steering.
edit: Yay!
Old 01-28-2013 | 02:29 PM
  #25251
EricW's Avatar
Oh shit, I might make it up there then. How late are you going to be open?
EricW is offline
Old 01-28-2013 | 03:26 PM
  #25252
blwaz23's Avatar
I wish I could go I need to break in some new tires
blwaz23 is offline
Old 01-28-2013 | 06:23 PM
  #25253
Joe Vass's Avatar
Hey what r u guys running for gearing in your 17.5 buggies I'm running 35 72.......but I still can get over that darn triple. Feels like maybe I need more forward bite? I'm lost. Help
Joe Vass is offline
Old 01-28-2013 | 06:27 PM
  #25254
redskins's Avatar
Put some timing on the motor, go up a few teeth on the pinion and hit the berm in the middle all the way back and you should have no problem clearing it. Hope this helps
redskins is offline
Old 01-28-2013 | 07:13 PM
  #25255
trevcoll's Avatar
Joe - I was running 34/69 (so pretty much the same FDR) with the Trinity D3.5 and having no problems provided I went at least 2/3 of the way out from the apex and carried some speed into the turn.
That said, I was double - singling the triple with my stadium truck with an Orion 17.5 cutting the apex pretty tight on the pipe and was able to hold nearly the same pace as my "cheater 17.5" buggy.
Don't get too caught up with clearing the triple. One bad jump that requires a marshall will wipe out any gains from clearing it the other 19 laps . Double - single the darn thing until you get the rest of the track nailed down.
Ok, so i've had my Yoda moment for the week. Now someone get me a beer
trevcoll is offline
Old 01-28-2013 | 07:23 PM
  #25256
Joe Vass's Avatar
Big trev, thanks buddy
Joe Vass is offline
Old 01-28-2013 | 07:59 PM
  #25257
EricW's Avatar
32x76 with 36 degrees of timing on the motor
EricW is offline
Old 01-28-2013 | 08:32 PM
  #25258
EricW's Avatar
Originally Posted by jaron_cc
When I first went to big bores on my Kyosho it wasn't that bad off but needed some getting use to the plushness. My experience with B4's is that I have to add a ton of weight to the rear of that car in order for me to have a sense of stability from the rear. Honestly try adding some weight and try a less aggressive front tire in order to tame the ae aggressiveness!
This was pretty spot on with my buggy and the big bores.
- I had to move the battery all the way back to get the rear end planted better although I eventually moved the battery up just a bit because I was getting a good amount of push when cornering with it all the way back.
- Also moved to softer springs up front and added a bit of weight as well.
- Removed the washers from under the front and rear camber links.
I'll see how it feels on Wednesday, I might go with lighter shock oil up front if I still get too much push.
Thanks for the suggestions and thanks to Alex for helping me work on the buggy today at the track.
EricW is offline
Old 01-29-2013 | 06:23 AM
  #25259
t0p_sh0tta's Avatar
You'll have to check my car out Eric. Alex and I have have very different styles, and very different setups.
Raising your camber link (aka: adding washers under the inner stud) will lower your roll center. This is where it gets confusing, lowering your rollcenter will actually make your car roll more in the corner. This roll is what transfers more weight to the outside tires, and creates traction.
By removing washers you've raised your roll center (lowered the camber link), which decreases roll through the corner. By decreasing roll, your car will rotate more through the turn, but if you go in too hot, the rear end will wash out because you don't have enough weight transferred to the outside wheel.
A secondary effect of messing with roll centers is a change on camber gain. Usually, compressing the suspension results in a slight (negative) camber gain. If your car has a lot of roll, but little camber gain, it'll suck. If your car has little roll, and a lot of camber gain, it'll suck again.
It's all a balancing act. I can show you better than I can tell you, but you guys are free to try my B4 with the shorty whenever you'd like.
p.s. Adding weight to the front will decrease your forward bite, as it'll take longer for weight to transfer to the rear wheels, and ultimately, there will be less weight transferred. I've actually been thinking about going back to the plastic steering rack to get a bit more forward bite. My car feels really balanced to me at the moment though. Almost like my mid motor cougar did, but with more forward traction.
edit: I'm running black springs up front and white out back. I had greens in the rear, and steering was great, but forward bite was non-existant.
Old 01-29-2013 | 07:08 AM
  #25260
+ YouTube Video
jaron_cc is offline
You have already rated this thread Rating: Thread Rating: 3 votes, 1.00 average.
