RC10B4.1 FT/WC
Old 01-16-2013 | 09:17 AM
  #27451
Razathorn's Avatar
I saw your post lol. And my spring collar rubbed. I dont think the shock cap was an issue.
I became unsure if I did anything after I wrote that, lol.
Razathorn is offline
Old 01-16-2013 | 02:09 PM
  #27452
rcfiend's Avatar
Hey is there anyone that has switched from the RB5 to the B4.1 and used the rims/tires on the B4.1? I'm trying to determine if the off set is the same. I tried using the rims from the RB5 and the buggy picked up a bad push, I swapped the the B4.1 wheels/tires and push went away.
rcfiend is offline
Old 01-16-2013 | 02:15 PM
  #27453
t0p_sh0tta's Avatar
Why not just measure the offset? I don't have any K wheels, but I can check Losi vs. Proline.
t0p_sh0tta is offline
Old 01-16-2013 | 02:18 PM
  #27454
Tradin Paint's Avatar
I have not switched from an RB5 to a B4.1 however I have/am using RB5 wheels on my B4 and have not had any issue. I guess my answer on the B4.2 thread was not good enough
Tradin Paint is offline
Old 01-16-2013 | 07:32 PM
  #27455
BillPear's Avatar
Originally Posted by 66Racer
Nice!! This belongs on the main post of this thread! Im gonna have to remember this if the "new" shock towers dont align the shock this good
I'll be over at OC_RC tomorrow (Friday) if your at the track look me up you can have a better look and I can answer any questions.
That is a good mod and I have been playing with it myself at home. But i have not put this on the first page for 2 reasons.
1) AE is making new tower and it might make this mod null and void.
2) The mod is nice, but the creator did not provide enough details on the mod for it to be overly useful. What sized screws did he use in the counter sunk holes. Where did he get the screws (part number)? How far should the tower be moved back(mm/inches)? What size spacers for the wing mounts are needed and where to buy them?
This MOD is complicated enough that it requires more details to be posted on the first page. I was under the impression he was still testing and perfecting the mod. How it effect handing? Did the body need to be trimmed? etc. No offense to the MOD creator.
"If" this became "the mod" for BB shocks. It would be great if the exact hole placement could be determined and premade drilling templates were created for those interested. Ideally you could make it out of steel. Then bolt it to you u-brace and drill out the holes according to the template. Maybe make the template and the rear spacers and missing 5-40 FHS screws included. So like a "BB Tower mod conversion kit". If i had the resources and the mod tested well, I would do it.
If you would like I'd be happy to provide more detailed instructions, for you or anyone else drop me a PM
BillPear is offline
Old 01-16-2013 | 08:15 PM
  #27456
dirtdog's Avatar
I would assume most people are running 3.0 degrees of inboard toe for med to high traction tight tracks? I know I read a few pages back that if the setups sheets don't say anything they are running the stock inboard toe.
dirtdog is offline
Old 01-16-2013 | 08:25 PM
  #27457
huzzler's Avatar
Yes 3 degree inboard toe with 0 degree hubs.
huzzler is offline
Old 01-16-2013 | 08:58 PM
  #27458
Wildcat1971's Avatar
Tech Prophet
sure pm me the details and i will put it on the first page.
Wildcat1971 is offline
Old 01-16-2013 | 09:31 PM
  #27459
66Racer's Avatar
Ah man thought you meant Thursday lol, I'm gonna be there Thursday for practice. Until I get my own transponder I don't want to race. Did the race at the end of the aka holiday bash as my first race and the handout transponder mounted to the body totally changed the way the car turned. Was gonna go mrc but now I hear the potential for conflicts at tracks that update the firmware or something.
66Racer is offline
Old 01-16-2013 | 11:21 PM
  #27460
mkennedy's Avatar
i run a similar mod, it moves the tower 8mm and i dont countersink the brace. stock screws and screws into the chassis, similar to original. you have to trim the rear of the body a little, but there are no conflicts with the tierods. only been running it for a few weeks, all is good so far.
mkennedy is offline
Old 01-17-2013 | 07:08 AM
  #27461
66Racer's Avatar
Good morning,
Is there an advantage to using the MIP diff gear and rebuild kit when I rebuild the diff? I'm in 17.5 currently but plan on going mod sooner or later. Also planning on either trying ceramic or AE carbide balls, any thoughts on what's most dependable in the diff in general?
66Racer is offline
Old 01-17-2013 | 07:18 AM
  #27462
Matt Trimmings's Avatar
Good morning,
Diff gear quality is the same, i have never had an issue with the standard AE gear. As far as diff quality i have had great luck with the regular AE Carbide balls for the diff and the Avid ceramic balls for the thrust.
Matt Trimmings is offline
Old 01-17-2013 | 08:07 AM
  #27463
Tech Prophet
The AE ball diff is fine. Some people swear by the BFast rebuild kit. I have been able to make the AE diff smooth with proper break in.
Old 01-17-2013 | 09:22 AM
  #27464
Good morning,
The MIP is cheaper than the Bfast. All of the issues I have ever had with any diff build or rebuild kit were caused by my own error, or rather lack of skill.
If you want to get really good at building diffs that last, buy a Losi 22. I had to build/rebuild the diff on my 22 a bunch of times before I got it right. Got lots of practice! LOL
zipperfoot is offline
Old 01-17-2013 | 10:00 AM
  #27465
vito's Avatar
can a b4.1 wc be upgrated to a b4.2 kit
vito is offline
