Xray T4 '13
#2418
I think you are talking about pin sweep. With the pins, for lack of a better term "toed out", that is called positive pin sweep. This will cause the car to turn in harder for what I have noticed. Negative pin sweep does the opposite. Basically positive pin sweep is like toe gain into a turn.
#2419
I have used it to numb out the steering . It gives it the feel of less steering by making the rear more planted . In slower areas of a track to me it turns tighter (smaller turning radius with shorter wheel base ) but thru chacanes I don't like it makes it seem lazy
When I ran outdoors I used this a lot to gain rear traction and have more steering in slower areas of the track
#2421
By placing more weight over the front tires u loose responsiveness in steering by making the tires have to work harder to move the car from left to right . Now at lower speeds it will give more steering cause u shortened the wheel base . And ur removing weight from the rear making it have less weight that can transfer wile cornering which usually helps keep it in line ... now I'm sure theirs a point where u can remove or add too much weight to one end to reverse this thought but I've swept my arms back 3mm ff/1.5mm fr and this concept held true to that extent
#2422
#2423
If you have the time this weekend would you be interested in driving my GT car? Its pretty good now, but the rear is washing out in the fast chicane and I have traction additive down both sides of the chassis after the race
#2425
#2426
I believe thats what i have on my USGT car, still using EA's Birds setup. BTW thanks for all the help you gave me on my T4 last sunday. Every time you suggested something, it improved my fast lap by .10.
#2427
Matts doing awesome for an 11 year old!
EA
#2428
Lol tks . I removed rear sway bar( with is driving style it got a little loose sometimes when he snatched the wheel) ,and added some droop.
2Likes
