The AE FActory Team B44.2 Thread >
Old 01-05-2013 | 02:13 AM
  #1726
ryanpatrickgore's Avatar
If your using gold barcodes then you will want the clay compounds most likely.talk to guys at the track, someone there probably already has it figured out.
ryanpatrickgore is offline
Old 01-05-2013 | 02:57 AM
  #1727
Originally Posted by Arigato
I've broken 3 so far...They were pretty good crashes though. I tried the Losi 22 cups and they are just a bit too small.
i broke mine on the 1st run, and have them all changed to avid spring cup.
so far so good, no problem at all.
http://www.amainhobbies.com/product_...-Spring-Cups-4
sion is offline
Old 01-05-2013 | 06:35 AM
  #1728
UN4RACING's Avatar
Originally Posted by LosiRacing7607
Question on the Aka rebars front and back...
Race on a indoor packed dirt (clayish) med to high bite where jconcept bar codes Gold and losi pinks hook up pretty good.
What compound should I get?? AKA Super soft be too soft or wait for the new clay compound? I have pretty good throttle control but sometimes I get trigger happy out of corners.
Should I try super soft?
Even a jconcepts green? Or are these compounds made for dryer tracks?
Just looking for tire before my kit arrives.
Our dirt sounds the same. Its top soil, the rebars are the best at out track and dominate the field. When the traction is real high a soft in the front and a super soft rear. The red inserts are a must. I would recommend no holes in the tire but 2 in the wheel. This will make the tire stiffer but if its to stiff you can add 2 hole at a time to the tire as needed to soften them up.
Our track is Medium traction most of the time. I run super soft on all fours and with 4 1/8th holes in the tire and red inserts. They last much longer than any other tire on the market.
UN4RACING is offline
Old 01-05-2013 | 06:46 AM
  #1729
What is the point of cutting the holes in your tires?
Advantage R/C is offline
Old 01-05-2013 | 06:50 AM
  #1730
UN4RACING's Avatar
Oh yeah race day has arrived. cant wait to get this bad boy dirty. Some thing tells me that 4.5 is going to be a force to be dealt with.
This lid fits so much better than the JC.
Old 01-05-2013 | 06:54 AM
  #1731
UN4RACING's Avatar
Air, so they can breath. I think I will do a vid and show why they are important. I have tried a lot of tricks with tires over the years but found the holes are as important as the oil in the shocks.
Old 01-05-2013 | 06:59 AM
  #1732
Vid would be helpful. After you make it you can ask the mods to stick it in Rookie Section or Off-road section.
Old 01-05-2013 | 07:05 AM
  #1733
UN4RACING's Avatar
I will buy some tires today. Its really best to see why Vs. trying to explain it.
Old 01-05-2013 | 07:43 AM
  #1734
Awesome looking!
What camber links are you using? Those look really good on this car.
Looking forward to your race report!
mlinder is offline
Old 01-05-2013 | 08:02 AM
  #1735
used hartson's setup last night except i ran short wheelbase and my car was the best it has ever been. Very consistant and a blast to drive. that run got me TQ!
love this car!!!
Attached Thumbnails The AE FActory Team B44.2 Thread-2013-01-04_23-42-18_225.jpg
Coolza is offline
Old 01-05-2013 | 08:03 AM
  #1736
vito's Avatar
how muck longer is this then a .1 car?
vito is offline
Old 01-05-2013 | 08:06 AM
  #1737
Matt Trimmings's Avatar
8mm longer
Matt Trimmings is offline
Old 01-05-2013 | 08:13 AM
  #1738
UN4RACING's Avatar
Originally Posted by mlinder
Awesome looking!
They are JConcepts. You have to change the link to a shorter one though. So its cheaper to run RPM but I like the different look. I will post how the ace goes.
http://www.jconcepts.net/store/index...products_id=23
  #1739
8mm Longer.
UN4RACING- Nice car! It looks dialed with the lid on it. Very stealth. I think it's funny that you say Rebars last are a long lasting tire though. I got some used with a kit I bought and they appeared to be almost new. They were awesome on the dusty outdoor track I used them on, but by the end of the day the middle of the tire was slick. I'm fairly sure they were super softs, so it could have just been that it was too soft of a tire for the surface I was running on, but they were hooked up, so I didn't care. Good luck in your race today!
Racer X8000 is offline
Old 01-05-2013 | 08:16 AM
  #1740
UN4RACING's Avatar
love this car!!!
Congrats. looks like a solid run with a 5 second TQ on the field. Looks pretty consistent. How did you finish?
