The AE FActory Team B44.2 Thread >
Old 01-02-2013, 09:45 PM
  #1576
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
Well I wanted configure it that way, but my other promatch batteries have the connectors opposite. So I have to be able to swap my leads back and forth.
ryanpatrickgore is offline
Old 01-02-2013, 09:48 PM
  #1577
Ps. Thought I'd try something different that nobody does anymore..
Paint the wing. Haha
Old 01-03-2013, 12:35 AM
  #1578
Tech Legend
Wild Cherry's Avatar
My B44.1
Wild Cherry is offline
Old 01-03-2013, 12:45 AM
  #1579
tom_chang79's Avatar
Thumbs up
Hey guys, will that center spur cover fit the original B44? My connector is getting eaten slowly...
tom_chang79 is offline
Old 01-03-2013, 04:37 AM
  #1580
UN4RACING's Avatar
Trader Rating: 22 (100%+)
It wont fit.
UN4RACING is offline
Old 01-03-2013, 05:27 AM
  #1581
memyselfandI's Avatar
I am looking for help here guys, have just finished building my b44.2 and the rear transmission is binding when I turn the wheels on power, the entire rear suspension moves up and down from full droop to about 3/4 droop, I have obviously done something wrong, any ideas
memyselfandI is offline
Old 01-03-2013, 05:41 AM
  #1582
Trader Rating: 57 (97%+)
So I've been slowly reading this thread as I slowly upgrade my b44 I got into a b44.2... I'm about to order the big bore shocks and motor mount so my question is what springs do you guys suggest? I'm running on a hard clay track without many big jumps.. Large track that's about half technical then half high speed. I looked back quite a bit but still haven't found much
Also, what's the difference between the new slipper vs the old one? Thinking about upgrading that as well.
CaseyDDR is offline
Old 01-03-2013, 06:00 AM
  #1583
MemyselfandI:
Did you install the limiter washers inside the shocks?
CaseyDDR: The new slipper won't fit; it's too thick. You can install the Avid Triad slipper which does a good job. I spent quite a bit to upgrade an old 44, and finally bought a real 44.2. Not so sure it's worth upgrading... I sold my 44 to get the 44.2 and I think it was less expensive this way.
Maxime is offline
Old 01-03-2013, 06:02 AM
  #1584
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Originally Posted by Wild Cherry
My B44.1
I belive you are looking for this thread:
http://www.rctech.net/forum/electric...-1-thread.html
Matt Trimmings is offline
Old 01-03-2013, 06:06 AM
  #1585
Originally Posted by Maxime
MemyselfandI:
Thanks, I have no issues with the current setup honestly, so I won't bother with that.
What about the shock springs? Good combination you might suggest? I'll be running 35wt in the front 30wt in the rear to try first. I know the big bores from what I've read everywhere are a huge improvement.
CaseyDDR is offline
Old 01-03-2013, 06:07 AM
  #1586
MemyselfandI:
Sure did 1 .030 spacer
Old 01-03-2013, 06:17 AM
  #1587
Does it moves up and down with the tires removed?? Out of balance tires maybe?
And they say to use 2 spacers IF you use the outer hole on the rear suspension arm.
Maxime is offline
Old 01-03-2013, 07:06 AM
  #1588
Trader Rating: 53 (100%+)
New b44.2 owner here and new to 4wd buggy in general. My question is on the diff housing shimming. I shimmed per manual instructions but each diff spins fairly free but not much side to side play. So my question is how tight should these be built, thanks.
GettinLapped is offline
Old 01-03-2013, 07:11 AM
  #1589
You want them tight, especially during break in. I always built mine too tight and then ran the car for a pack or two then take out a shim or two (depending on how tight you had it). You dont want side to side play.
Old 01-03-2013, 07:19 AM
  #1590
Sounds good, thanks. One assembly was pretty loose I could spin it and would rotate 4 turns easily and the other maybe a turn.
