The AE FActory Team B44.2 Thread >
Old 01-03-2013 | 08:12 AM
  #1591
ryanpatrickgore's Avatar
Originally Posted by memyselfandI
I am looking for help here guys, have just finished building my b44.2 and the rear transmission is binding when I turn the wheels on power, the entire rear suspension moves up and down from full droop to about 3/4 droop, I have obviously done something wrong, any ideas
It's the cva. The pin is throught the large hole rather than the small pin hole. Take it apart and rebuild it. This happened to me.
ryanpatrickgore is offline
Old 01-03-2013 | 08:44 AM
  #1592
Originally Posted by CaseyDDR
Thanks, I have no issues with the current setup honestly, so I won't bother with that.
What about the shock springs? Good combination you might suggest? I'll be running 35wt in the front 30wt in the rear to try first. I know the big bores from what I've read everywhere are a huge improvement.
Run the standard kit setup. The kit is dialed out of the box, maybe drop down a spring in the rear and a step in oil if needed but that's it
Old 01-03-2013 | 08:55 AM
  #1593
+1 I'm running mine with the kit setup except I changed the front oil to 37.5 and the rear to 32.5 ( as per this setup sheet ) It's totally dialed on an indoor clay track (med to high traction).
Racer X8000 is offline
Old 01-03-2013 | 08:58 AM
  #1594
Wild Cherry's Avatar
Originally Posted by Matt Trimmings
I belive you are looking for this thread:
http://www.rctech.net/forum/electric...-1-thread.html
No
I have the right thread , do you have B44 Matt ?
Wild Cherry is offline
Old 01-03-2013 | 09:10 AM
  #1595
Matt Trimmings's Avatar
No
why the pics of the .1 then?
Matt Trimmings is offline
Old 01-03-2013 | 09:32 AM
  #1596
Because this is the B44 thread not just for b44.2..
BTW my B44 is in construction, changing it into 44.2
Got a B44 Matt ?
Show me !!!!
Old 01-03-2013 | 09:35 AM
  #1597
Got a B44 Matt ?
Show me !!!!
Old 01-03-2013 | 09:36 AM
  #1598
fq06's Avatar
Got a B44 Matt ?
Show me !!!!
This is The AE FActory Team B44.2 Thread.
But anyone is welcome... it's just a forum.
Nice ride too WC.
fq06 is offline
Old 01-03-2013 | 09:40 AM
  #1599
I don't need to have a B44.2 to post in this thread...it's not a prerequisite. I am just here to help others. I have owned pretty much every AE electric car over the years and offer help to anyone.
Old 01-03-2013 | 09:42 AM
  #1600
Likely I missed it but doesn anyone else have the problem of the slipper coming loose during the race?
Bigfoot1 is offline
Old 01-03-2013 | 09:48 AM
  #1601
I had that problem... But I installed the oring on the slipper shaft and the blue nut after... The oring should go INSIDE the blue nut. I tried it last night and the slipper didn't come loose.
Maxime is offline
Old 01-03-2013 | 09:53 AM
  #1602
You mean you come here & ask why I post here & you don't even have one !!!!
I understand Matt ...
This ride is not cheap ....
I was lucky ...
Got mind from a teammate who just finish it when his B44.2 came in the mail the next day ..
called
KICK DOWN ....
Its got all the bing on her including the Triad slipper...
Still had to purchase the Flow , servo , receiver & T.P. myself...
Next I order all the B44.2 parts .....
Old 01-03-2013 | 09:55 AM
  #1603
I was lucky ...
called
KICK DOWN ....
Next I order all the good B44.2 parts .....
wow
Old 01-03-2013 | 10:03 AM
  #1604
wow
PFKAOG is offline
Old 01-03-2013 | 10:05 AM
  #1605
Matt , you still here ?
