Like Tree195Likes
Novarossi engines thread
Old 12-11-2012 | 02:48 AM
  #4486
The keep on has a different bore/stroke and does need some cut outs in the sleeve to prevent the rod is hitting the sleeve. With the bore/stroke difference I doubt the JP P/S set is also giving the right offset and timings for a Keep-on crankshaft/crankcase.
Roelof is online now
Old 12-12-2012 | 08:47 AM
  #4487
SOLOARTIST 702's Avatar
so with that being said can i use the p/s/r set #08569 in the R09 case just checking thanks for the help guys
SOLOARTIST 702 is offline
Old 12-12-2012 | 11:09 AM
  #4488
Probably it will work but you will end up with a smaller capacity, somewhere 3.3~3.4cc
And still I can not say something about the offset of the ports and timings.
Old 12-12-2012 | 07:31 PM
  #4489
thanks
Old 12-25-2012 | 02:06 AM
  #4490
Originally Posted by stefan
If you can get your hands on them, Sirio plugs are awesome. IDM is the same plug btw.
I have the same problem plugs keep dying very easily. What sirio plug do I need?
speed6 is offline
Old 12-27-2012 | 08:41 PM
  #4491
beaim's Avatar
INSTATE OF 0.3 SHIM ON 16 %. SOME ADVICE GIVEN IS ADDING 0.1 SHIM ON IT TOTAL 0.4.
beaim is offline
Old 12-28-2012 | 02:08 AM
  #4492
Indeed, some engines have a tight compression not giving any tolerance on a lean setting.
Also take a look at Merlin Glowplugs, very good and affordable. They can handle a lot.
Old 12-28-2012 | 04:23 PM
  #4493
DS Motorsport's Avatar
Sirio 6 for a .12 and 16% nitro. Might need a 7 when you use more nitro.
DS Motorsport is offline
Old 12-28-2012 | 07:41 PM
  #4494
Stick with Nova plugs. You'll damage the threads when you use other plugs. If you want a colder plug try a C7GTF or C8TGH. The C8TGH is a very tough plug and it should never blow in a .12.
desotoracing is offline
Old 12-29-2012 | 04:34 AM
  #4495
if use C8TGH,would the performance effected?
kyosho malaysia is offline
Old 12-29-2012 | 06:18 AM
  #4496
bassman2's Avatar
The tunning window will be narrowed slightly but you can tune the engine slightly leaner.
Andy Liu "Flyin' Hawaiian"
bassman2 is offline
Old 12-29-2012 | 06:58 AM
  #4497
HHH's Avatar
HHH
The owner of ORCAN engines told me that plugs need to be fresh/new. If a plug is in the package for more than 6 months--the life and performance of the plug decreases a lot. He also told me that Nova changed their manufacturing for the better in early 2012. He is a big fan of the nova C7GTF plug for .12 engines.
Since getting fresh/new C7GTF plugs (for 4-5 months now), running in tropical (hot and humid) weather, I have had my best lap times, my plugs now last 2-3 times as long as they used to and there is no noticeable difference in power over the 6F.
I am a believer.
Sadly, it is hard to tell the manufacture date of plugs so buy from someone who you trust and who gets them as direct as possible from Nova.
HHH is offline
Old 12-29-2012 | 09:32 AM
  #4498
leaner would it effect when reach the peak rpm and also the engine life?
Old 12-29-2012 | 09:36 AM
  #4499
I am a believer.
do you mean the filament will oxidized if keep it too long
Old 12-29-2012 | 12:44 PM
  #4500
bassman2's Avatar
Will give you slightly more power overall. As long as the engine is properly tuned overall then engine's life will not be compromised.
bassman2 is offline
