RC10B4.1 FT/WC
Old 12-29-2012 | 09:33 AM
  #26461
racer1812's Avatar
Super Moderator
Want to buy and sell..we have a section for that. Lets use it please.
racer1812 is offline
Old 12-29-2012 | 09:51 AM
  #26462
huzzler's Avatar
Originally Posted by associatevalley
I've got a question for those of you that use 4 scales to check weight distribution. What scales are you using, as they can be quite pricey. Thanks.
I've seen guys use the little scales from harbor freight. They have them for $15 each but you can use the 20% off coupon. They work awesome. I try and use it when I see one of them at the track with them.
huzzler is offline
Old 12-29-2012 | 09:52 AM
  #26463
BRSracing's Avatar
Originally Posted by JEFFs SC10
So do you guys think a b4.2 is coming out? Id hate to buy a b4.1 put bbs on it etc and then a month later have another kit come out lol.
I am sure they will come out with something but when is the big question.
BRSracing is offline
Old 12-29-2012 | 09:58 AM
  #26464
huzzler's Avatar
Anyone know where to find a setup with t4 chassis? Or anyone else have experience with using it? I tried it once before but didn't really like it. Kinda forced to use it for awhile since last night practicing someone jumped the track with an scte and hit me head on. Snapped my chassis and top plate in half. Can't really afford new chassis right now so gonna try giving the t4 chassis a try again.
huzzler is offline
Old 12-29-2012 | 10:23 AM
  #26465
mashimarowu's Avatar
Originally Posted by zipperfoot
And put your o-rings inside the shock collars.
Lol I already edited my post and said I solved it. Just mistakenly read my instructions. No need to have people keep posting about it.
mashimarowu is offline
Old 12-29-2012 | 11:47 AM
  #26466
BillPear's Avatar
Whats the screw in the top plate in front of the servo arm for?
http://i.imgur.com/yasxs.jpg
BillPear is offline
Old 12-29-2012 | 11:49 AM
  #26467
Waflet's Avatar
Hideeho
I've got a kid at the track today with a brand new b4.1 with an MMP & 1408. What kind of gearing does he need for it? He's currently at 28/81 & it's rediculouly slow. How high does the gearing need to be for it?
Waflet is offline
  #26468
Wildcat1971's Avatar
Tech Prophet
Lol the front body pin. He is not using velcro
Wildcat1971 is offline
Old 12-29-2012 | 11:50 AM
  #26469
YankeeFan123's Avatar
It's for those who run body clips, that's the one for the front
YankeeFan123 is offline
Old 12-29-2012 | 11:51 AM
  #26470
BillPear's Avatar
Thanks, Worlds kit doesnt have that
BillPear is offline
Old 12-29-2012 | 11:56 AM
  #26471
Tech Prophet
Originally Posted by Waflet
Hideeho
Is that the 4 pole motor? Either way that motor should be overly fast
Old 12-29-2012 | 12:18 PM
  #26472
Cain's Avatar
I am gathering info to give to the OP for this thread. Anyway, how does this info sound for the U-brace mod:
The ubrace mod is done in conjunction with the
CHub. From my experience, it helps the car rotate is little better on a higher bite surfaces. I have found on low bite surfaces that it is pretty awful. Because the rear will slid a little and square up better, it adds a little more steering on the entry of the turn and when power is applied, it will square up nicely. Again, this is mainly for higher bite tracks. IMO if your running double Dee's you probably want the A hub. If your running a Bar code, beam or suburb type of tire, the C hub and ubrace mod might be for you. Like Matt said, the avid carbon upper is nice because it is an all in one A/C hub and is cheaper than the AE C Hub.
Does anyone have pictures of this mod, before and after?
Cain is offline
Old 12-29-2012 | 12:29 PM
  #26473
Waflet's Avatar
Hideeho
Yes, it's the small 4 pole. Right now it is really slow down the straight & won't clear a double with plenty of run up room. Is any one familiar with this motor at all? How tall can it be geared?
Waflet is offline
Old 12-29-2012 | 12:56 PM
  #26474
Tech Prophet
Try 30/72 assuminf ut is a 3300 kv
Old 12-29-2012 | 12:58 PM
  #26475
All the times I've walked thru harbor freight I didn't notice scales, looks like I'll take another look.
Jmuck, that scale awesome, didn't see a price though. guessing at least a hundo. If I ever get into on road I may just try it out. Is limit is 500g x4 so no good for 1/8th.
associatevalley is offline
