RC10B4.1 FT/WC
Old 12-28-2012 | 10:23 AM
  #26371
Originally Posted by huzzler
Just wondering,you guys running the shorty packs in 17.5 class. Do you leave the weights in the rear? I run full packs now and I have ballast weight and 1/4 oz each rear triangle. I have tried removing the weights and the car just loses alot of traction. So I guess what I'm trying to say is the whole point of running the shorty is to reduce weight and improve handling right? So to me it wouldn't make sense to run the shorty without weights. As far as handling with the shorties,I don't think I can get my buggy to handle any better than it is now its awesome. Guess I should maybe try and borrow one and try for myself.
when I ran 17.5 with the shorty I kept the ballast, the 1/4 in the rear triangles, 1/2 next to receiver and that was it. I even went to the plastic hingepin brace on the front. It's preference though. Try it with the weight and with out and see how you like it better.
Bob Barry is offline
Old 12-28-2012 | 10:26 AM
  #26372
Wildcat1971's Avatar
Tech Prophet
how well does that plastic brace hold up?
Wildcat1971 is offline
Old 12-28-2012 | 10:27 AM
  #26373
Originally Posted by Gene158
I've only run the buggy twice so far and both times I used a full size pack because that's all I had. Can't complain about the way it handled but I have nothing to compare it to so I'll see how it is with the shorty. I just hope I didn't waste my money on the shorties.
I don't think you waisted money at all. The only way to know what works best for you at your track is to try it. If you decide you dont like the shorty, well... At least you know. You can then move on. I have spent a fortune trying to find the best set up for me. If your in the hobby for the long run, then it was worth it. You can always sell them or use them in another car, or for practice. Cant tell you how many times i sold stuff and wish i still had it when i got another car.
The cup is always half full is the way i like to approach things.
zipperfoot is offline
  #26374
t0p_sh0tta's Avatar
Just fine.
t0p_sh0tta is offline
Old 12-28-2012 | 10:32 AM
  #26375
I've broken one. But the hit that I took would have bent the metal one (don't ask). Just like any other part, it wears.... but I mean I think it's like 3 bucks. Just replace it once every other month and call it a day.
Old 12-28-2012 | 10:33 AM
  #26376
Speaking of motors, i have been running a Tekin 13.5 in my buggies for over a year, and a x12, 7.5 for even longer. How long do motors last? Do they lose power over time? Do they need a rebuild? I am not that good that i can sense an under performing motor, but i love to upgrade/rebuild if needed.
Old 12-28-2012 | 10:37 AM
  #26377
when they lose their smoke, you need to replace em. Unless you can find a way to put the smoke back in
Old 12-28-2012 | 10:42 AM
  #26378
I don't have any extra smoke, but maybe I can find some mojo.
Old 12-28-2012 | 11:20 AM
  #26379
YankeeFan123's Avatar
Originally Posted by idrummerboy13
I had my orion 7.5 in and it had very little punch. I threw my 10.5 back in and got more low end and more control. Suddenly I was pulling very fast laps, I just need to get to the track on a more consistant basis...but dont we all
I was using green slicks and boy I couldnt stop the wheelies. I am going to try and loosen up my car...
You're lucky. My car has gradually been losing traction. The track has been consistent but my car continues to get looser. I have done several things like softer rear springs, lower the rear ball stud, and now I've gone from C hubs to B and it finally seems more locked in. If it gets loose again I don't know what I'll be able to do. Oh yeah I've also made the rear link longer too.
YankeeFan123 is offline
Old 12-28-2012 | 11:26 AM
  #26380
t0p_sh0tta's Avatar
All you need to renew a motor is a rotor and bearings. The can is fine until it meltsdown, or falls apart.
Old 12-28-2012 | 11:42 AM
  #26381
mashimarowu's Avatar
Originally Posted by Cain
Initially I would have said its your servo saver (stock assembly) letting go but you did say you have the avid steering block.
To me at least, is it possible that your servo itself is having issues? Anyway you can try a different brand servo?
Doubt its my servo... I have the savoc 1257 if you were curious and it is fairly new.
Originally Posted by Scrubb
Its sounds like your your front tires are touching part of the front suspension and are locking up. Set your car on a car stand, free spin the front tires, and turn the front tires left and right with your controller. Are the tires rubbing on the suspension causing them to lock up? If they are, something is assembled incorrectly (I would check and make sure the black plastic spacer is correctly behind the castor blocks - a common mistake that would cause that, the second is that the left and right castor blocks are on the wrong sides).
By front tires touching suspension, do you mean any part of the front A arm that could cause the wheel to stop moving on full lock? If so, then no, my wheels are not locking up, I have my endpoints adjusted so that doesn't happen. This is a stock RTR car that I have slowly upgraded myself, so my castor blocks are on the right side and I checked and also my spacers are in the right place.
mashimarowu is offline
Old 12-28-2012 | 12:03 PM
  #26382
Kellen Guthrie's Avatar
Originally Posted by 66Racer
Im guessing by your location that is your OCRC setup? I just got back from practice and am pretty happy with how its driving, currently Im more focused on just putting down a ton of laps to get practice in but I cant help but want to try adding a 3rd limiter in the front (i still have v2 shocks).I have to double check my shock mount but everything else is the same. Would the 3rd limiter make a big difference in on throttle low speed steering? I get a slight push still but learned to work with it. If I can get a little more throttle during the slow sharp turns at ocrc I think the setup I have would be perfect.
I have already messed with the diff, I think its just that the rear is so planted its moving all the weight to the back. oil and springs seem good everywhere on the track, I dont think I wanna change the green rears but was thinking of going to a 30wt in the back or try the 3rd limiter in the front shock. Would appreciate your input.
Adding more limiters in the front will take away front droop which will take away weight transfer to the rear while on power. So if you add front limiters yes you will get more on power steering.
Kellen Guthrie is offline
Old 12-28-2012 | 12:07 PM
  #26383
Originally Posted by Jmnay_83
I was wondering what motor you guys are using for mod buggy? I have been out of the whole electric game for the last five years or so since brushless and lipo packs have really came into the scene. Any help would be appreciated. Oh and I am using the new lrp flow esc.
For b4 start out with reedy 7.5 no timing and go from there. Gearing is 78/22 and for modified i'd go with a wolf pack. They're a low profile long pack that give you a lighter car but it'll give you a planted feeling unlike a shorty. Plus they're like $55 so they're cheap lol.
Old 12-28-2012 | 12:53 PM
  #26384
BRSracing's Avatar
If you have checked everything for smooth movement and the end points on the radio are set your servo is most likely the issue. At our track I have seen a fair amount of issues with savox servos, even newer ones. I know most have to run a capacitor on the recevier with the savox. The capacitor has solved most issues.
BRSracing is offline
Old 12-28-2012 | 01:30 PM
  #26385
Cain's Avatar
+1 . Regardless if its newer or not, they can still fail on you.
I recommended swapping the servo as its relatively easy to see if its the issue. Process of elimination. Now if this was an SC10 4x4 ... yeah, that could be more involved lol.
Cain is offline
