U.S. Vintage Trans-Am Racing Part 2 >
View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
Like Tree4333Likes
Old 12-17-2012, 11:56 AM
  #3316
savageboy69's Avatar
Trader Rating: 93 (100%+)
i use sxt and dont traction roll, with a proper setup you wont, and i dont need a ruling from anyone to tell me what ive read
savageboy69 is offline
Old 12-17-2012, 12:00 PM
  #3317
Odin544's Avatar
Originally Posted by Jonesy112
but where you do, as a rule maker and tech enforcer draw that line? How do you define it?
And yes, finger nail polish remover does remove super glue, but it contains toluene, which is a mild paint thinner, which will soften then tire. Cant use it, it alters the tire.
Guess we just tell them you are screwed out of a set of tires, throw them away and go spend more money and try again?
And you two didnt answer my last question in my post.
In case you havent figured it out, Im being an annoying A$$ on purpose to illustrate a point that you cant define every scenario. RobK and Myron will just have to give an official ruling on the sidewall wont they?
If you used the fingernail polish remover to soak your tires in yes it would soften them. Using it to wipe something off your tires is not softening them. Common sense
We do use traction compound yes. But we don't soak our tires in it before we even mount them. It's used 5-6 minutes prior to running. Again, common sense.
You trying to be an "annoying a$$" doesn't bother me at all. This is simply an online discussion. We don't have to agree. I dont get upset because of something I read online. Ultimately each track will/does do what they feel is best for them.
Odin544 is offline
Old 12-17-2012, 12:04 PM
  #3318
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Odin544
You would be wrong. This is also commonly done with F1 tires and it makes a considerable difference.
I am aware of this as I run F1 also. As I said if you properly glue the tires from the start the sidewall is already stiff since you are putting glue on the underside of the sidewall to glue them to the rim. F1 tires don't glue up the same as VTA tires so adding glue to the outside of F1 tires will alter the tire.
Jerz616 is offline
Old 12-17-2012, 12:08 PM
  #3319
Odin544's Avatar
Gotcha. I don't see a need for it in VTA to be honest. I agree with you though. The tire sidewalls are already pretty stiff. Maybe its the soaking the tires in traction compound that softens the sidewall?
Odin544 is offline
  #3320
ok i will explain this slowly, yes the way vta tires are mounted they are stiff, but with rubber being on the side wall its grippy, by glue them it still stiffens them and makes them less grippy
Old 12-17-2012, 12:33 PM
  #3321
rcsuicide's Avatar
Pardon my interruption ... I just want to wish everybody on this VTA thread a Merry Christmas!
rcsuicide is offline
Old 12-17-2012, 12:50 PM
  #3322
hot or not her ass wouldnt be sitting on my hood
Old 12-17-2012, 12:52 PM
  #3323
NOVAK Electronics Presents..........................
Coming April 2013
ercwhtsd is offline
Old 12-17-2012, 12:57 PM
  #3324
rdx4vta's Avatar
you guys sure know how to turn someone off from attending a 'major' race with all your nitpicking back and forth crap...
rdx4vta is offline
Old 12-17-2012, 01:04 PM
  #3325
markt311's Avatar
Trader Rating: 34 (100%+)
Originally Posted by DARKSIDE
O M G
That's why I stay off this thread. No useful info, just a bunch of nitpicking
markt311 is offline
Old 12-17-2012, 01:16 PM
  #3326
nf_ekt's Avatar
Trader Rating: 115 (100%+)
I kinda' dig the HPI 78 Trans Am body, how 'bout yourself?
nf_ekt is offline
Old 12-17-2012, 01:22 PM
  #3327
Kevin K's Avatar
Trader Rating: 32 (100%+)
Adding glue to the outside sidewalls of the tires is used with EVERY form of RC cars Carpet racing. There are no rules to prevent this or stop this at any ROAR or IFMAR race why is this an issue for some of you VTA guys? This is a fairly common thing done I dont see there being any issue with this what so ever. If you are taking issue with this then there really will never be a set of rules that will make you happy and you are just looking for something to complain about on the internet.
Kevin K is offline
Old 12-17-2012, 01:28 PM
  #3328
CSeils's Avatar
Trader Rating: 54 (100%+)
Not Bad...http://w12cars.com/wp-content/upload...ro-girls-5.jpg
CSeils is offline
Old 12-17-2012, 01:49 PM
  #3329
nf_ekt's Avatar
Applause Good Sir. Free cold one on me, should we ever cross paths
nf_ekt is offline
Old 12-17-2012, 01:54 PM
  #3330
rdx4vta's Avatar
Originally Posted by CSeils
Not Bad..."link i can't repost"
not bad at all...
rdx4vta is offline
