MTX 5
Old 11-21-2012 | 11:56 PM
  #2551
rc-goods's Avatar
Default Zero Force & Evo Workshop Product For Mugen MTX-5
Zero Force Mugen MTX-5 Bearing Kit Set (17pcs) (ZF-N12003)
EVO-Workshop MTX-5 7075 T6 Hardcoated Chassis (EVO-MTX5-ET2401)
www.rcgoods.com
rc-goods is offline
Old 11-22-2012 | 01:32 AM
  #2552
hi who has used new chassi with old gears we ran old ones at nats with brace but i would like two know if i can still use old ones /knot having trouble so i will order new version next time if they are better not grumpy or winging just don't like wasting $$$$$
greg
greg.dawn is offline
Old 11-22-2012 | 10:26 AM
  #2553
Here's JJ Wang's setup from Thailand. Its pretty unique to RC Addict due to the conditions they were running in.
thunderbt3 is offline
Old 11-26-2012 | 12:47 AM
  #2554
bigbank66's Avatar
Default Mtx5r
When r we going to see the mtx5r wit all the new option parts??? Mugen jump on board...
bigbank66 is offline
Old 12-01-2012 | 03:55 AM
  #2555
hi i know some of you had mtx4r before mtx5 we have still got two have just changed oil in front diff and it drives like shit i put 30000 in back and 100000 in front i have know idea of what was in it before because it was never changed but i think it was 80000///i tried 50000 in back but that did not feel right have any of you got any ideas on correct oil not in book because it came with one way no front diff at least i am not whinging about our 5//ha
greg
Old 12-01-2012 | 05:18 AM
  #2556
lil-bump's Avatar
greg
When I ran the x4. I always liked 50k front and 30k rear.
Pass you soon...
lil-bump is offline
Old 12-01-2012 | 05:57 AM
  #2557
Bishop's Avatar
Original fill is 200k front, and 50k rear.
I had some success recently with 30k rear and 100-something-k front, though like many things, won't work for everyone.
Edit: Oops, I though you were talking of the five, stock fill on the 4 acording to the Mugen site docs was 10k, with Fukuda running 30k at some places on his setup sheets, and 50k in the rear with a locked front at our track a long time ago Greg.
Bishop is offline
Old 12-01-2012 | 07:41 AM
  #2558
YLLIB's Avatar
[QUOTE=lil-bump;11502596]When I ran the x4. I always liked 50k front and 30k rear.
I ran 50k front and 20k rear at Nebraska Nationals in 2010, ran well. If you drive it real hard on tight sweeper track and not smooth on the throttle in that area only, it will diff out a little but the car rotates nice everywhere else and does not diff out. I would go a little heavier rear diff oil like lil-bump has. I tried the car last week and pulled it off the shelf since 2010 and the car ran perfect. Selling it today, I will miss this car, great car for its time.
www.acornracingusa.com
PRODUCTS FOR SERIOUS "NITRO" ON ROAD RACERS
YLLIB is offline
Old 12-01-2012 | 04:58 PM
  #2559
thanks i always ran one way because you need to think about all that finger movement all that braking only slows you down/me/grandson just tells me i am to old but i still like to run car when it is good and it was really fast before we pulled it apart now it has a mind of its own i yous to say if it ant broke than do not mess with it but after 4 years of racing it really needed some work
greg
Old 12-03-2012 | 03:07 AM
  #2560
@Greg:
I was also running the 4R and the best setup for me personally was 80.000 front and 60.000 rear (Xray Oil). The small gears without the O-rings made the diffs really smooth.
Worked well all the year on different tracks. I tried a lot with diff oils, but always got back to 80/60.
Cheers
Darkstar900 is offline
Old 12-11-2012 | 08:32 AM
  #2561
does anyone have the part number for the "large plastic screw" which is used in the rear body mount? The large plastic screws support underneath the rear of the body...
Ghett0 is offline
Old 12-11-2012 | 08:37 AM
  #2562
rpoage's Avatar
MUG H1006
http://ashfordhobby.com/SearchResult...KeyWords=H1006
rpoage is offline
Old 12-11-2012 | 10:10 AM
  #2563
shanwright's Avatar
Default I use these and they work a treat !
Try these.
http://www.rc-mushroom.com/product_i...ew-pcs-p-16269
shanwright is offline
Old 12-11-2012 | 02:49 PM
  #2564
DS Motorsport's Avatar
Default Fueltank dimensions
For a project I'm working on I'm looking on getting some dimensions of the MTX-5 fueltank.
To determine whether the tank will work or not I will need the following dimensions:
-A Length of the tank within the radiotray
-B Width of the tank within the radiotray
-C Length of the tank part which is on top of the radiotray
So if any of the MTX-5 drivers could measure these dimensions for me I would be very grateful.
Thanks in advance.
DS Motorsport is offline
Old 12-12-2012 | 02:26 AM
  #2565
Bundy_Bear's Avatar
Thanks in advance.
Daan
If you want to turn your Cap into a Mugen, why not just buy a Mugen!
Bundy_Bear is offline
