RC10B4.1 FT/WC
This is what you want if you want to run a VTS on a B4/T4/SC10. I don't know if the rate is similar, but it is shorter than the updated V2 spring. This allows you more room for adjustment. To correct you again, it is listed as a part for the original B44.
So if I run my shaved U-Brace with 2mm washers under ball stud, with A hubs that's like the stock kit height with the normal U brace and one Ballstud washer?
I'm asking as I just got my Avid A-C hubs. My local track gets rough, but other tracks I run out of town are smoother
I have the stock AE B4.1 (XP SC450-BL ESC and Reedy 3300kv sensorless motor). I want to upgrade to be more competitive. Budget is around $300. I am looking at the CC Mamba Max Pro w/NC1406 4600kv motor $270. I am new to racing and need some advise. Would this be a good upgrade or can someone recommend something better? Thanks for you help.
You could get a Tekin Rs combo for $250 or an LRP combo for $260 or the Viper combo that was listed above. Just because castle has been around the brushless tech for a long time doesn't mean they are the best. Lots of other alternatives available. I would get a hobbywing setup before I got a castle.
[QUOTE=t0p_sh0tta
This is what you want if you want to run a VTS on a B4/T4/SC10. I don't know if the rate is similar, but it is shorter than the updated V2 spring. This allows you more room for adjustment. To correct you again, it is listed as a part for the original B44.[/QUOTE]
I did look up the part , not listed even on the B44 parts page .
learn something new everyday though...Thanks for the info..
Hey Nick,
If you want one of the slippers, just get the VTS. From what I can tell, they both offer similar performance, but the Avid is half the weight. It's ideal for 17.5 guys. I will have one eventually for my 17.5 car when I finally finish it, but since you run mod, it really doesn't matter much.
If you really want the Avid, make sure you grab at least 2 of what ever spur gear you want. Since you run mod, I would get 2 81's and 2 78's. If you ever decide to run 13.5 or 17.5, then you want 69 and 72 for spurs.
See ya at the track on Sunday. Bring your car with you so we can get it ready...even if you aren't going to run it.
When I can get clean 6 minute runs, I'll worry about those .010"
Hideeho
I have started using garodisk from rcshox.com & REALLY like it. I have done some stess testing on it doing repeated launches from stop. Once I got the preasure set (it only took 2-3 launches) it retained the exact same amount of slip for the next 20 launches. I have been running it for almost 2 months & the only time I had to touch it was at a different track that was REALLY loose (ended up with 2.5* rear toe to get it inline). I pulled it apart last weekend just to see the wear & I can tell it is used, but that is it. There is also no additional wear on the spur (wouldn't expect any) or on the aluminum plates. I am VERY happy with the Garodisk.
Thanks for posting this pic Grasschopper!
I wonder though if this would work
http://www.amainhobbies.com/product_...let-Connectors
Too funny..... I was just having the conversation with someone last night or the night before about this. I was saying "if it was really that much better and worked, why don't we see Ryan and Ryan doing it. Even in testing. In today's age of social media, SOMEONE would get a pic"
